Hi, ive just started my first guitar build and wanted to ask questions, share my thoughts and get feedback etc..
Well firstly heres a mock up of what i hope it will look like,
The humbucker will be a dimarzio super distortion
Fixed gotoh bridge
Left handed rg550 neck, so it will look like reverse headstock, maple fretboard
Volume knob only, no tone
Fluorescent Orange colour!
Now heres the thing which is a little different, im going to use american oak for the body. Basically i got a free slab of oak and thought ' i wonder if oak would make a cool guitar body lol'. Ive looked over the net and not seen many people make oak guitars so i thought i would give it a go. I know its heavy and dense so its hard to work with and the body may be a little heavy, but im fine with that. Just interested to see how it will turn out, and if its horrible it was free anyway haha.
So share your thought on what you think of this project, any ideas/feedback would be cool,
whtwlf: Yea i love orange guitars too haha. I was thinking about an edge pro, but ive allready got an ibanez with one and just fancied a fixed bridge, who knows i may put a edge in later on..
ikosaed: Yep the logo will be upside down, not to bothered, adds a touch of something different
So at the moment i have the neck and iam ready to rout the body, just got to make a template first.
One thing iam unsure about is the scale length, i know its 25.5, so its 12.25 inches from the nut to the middle of the 12th fret, but when i measure the next 12.25 inches to the bridge whixh part of the bridge do i measure to? Just need to know so i can posistion the bridge correctly,
From the nut to the middle of you sadles,your sadles have to be in the middle of the baseplate,meaning;you can adjust your intonation aswel as up and down.
i wouldnt recomend oak as a bodywood, its a verry poor tonewood.
If you want heavy and dense wood go for mahoganie instead.
Try to get a good piece from a luthier.
GOOD TONEWOODS MAKE YOUR SOUND.
Unless ofcourse you like active pickups and loads of effects.
Looks like a great project, and why not try the oak?
I would definately put it together and try it before you paint it though, just in case it isn't a great sounding piece, unless of course you want to practice painting.
Why do you want the old style heel? With an AANJ neck/heel you get a great deal of reach to the upper frets. If you have an old style neck then it is a no brainer.
Putting a lefty neck on a righty guitar is dead easy. You just need to do a little re-profiling.
Yea i might try it out before i paint it actually, thanks for the tip.
Well i have a AANJ on my other ibanez and agree its great for upper fret access, but i wanted to try the old style, also the neck ive got is the old style too lol.
Whats the re-profiling i need to do to make the lefty neck fit? im about to make the templates so dont want to get them wrong haha,
I read a rumour once (and I am pretty sure that it isn't true, but I did read it) that Brian May's Red Special is made of oak. George Lynch also tried it at one point, but it didn't go anywhere.
Yea, im a carpenter so i use routers on a daily basis, amazing tools but dangerous like you say. Its good being a carpenter because ive got all the tools i need so i wont have to go and buy any.
I heard using a grinder with a rough pad on is a good way to do contours, is this correct or are there better ways?
Ok im about to order the bridge and ferrules, just wanted to check with you guys that they are correct and will work with the neck string spacing wise,
this is the bridge, was hoping to get black but apparently they dont do solid black anymore, is this true? can i get a solid black one from somewhere?
The bridge looks ok to me but i cant say forsure cause i dont know about the messurments.(al my ibi's are floyds)
Have you thought of a "tight end bridge" found on the FR series?
They look pretty solid to me!
String ferrules are okay!
Your using a ibanez neck wright??
Whitch one?
Ive got a neckplate of an RG 550 left (square heel)
I did a bit of research on the bridge and it looks like they are used on most of the fixed bridge pgm models, so i think it will work with the neck i have, also this makes me think its a good quality bridge. Never heard of the tight end bridge.
Ok il get those ferrules, thanks!
Im using a rg550 neck so the neck plate you have would be perfect, does it have the gasket and screws? Could i see some photos?
Neckplate,gasket,screws its al there.
Send me your email adress threu a pm so i can send you pictures.
I'm doing a project on a rg550 at the moment.
Burnt and oiled an old body and giving it a leftys neck(same as you) trowing in a clear pickguard with green singlecoil in the neck and hum at the bridge.
Everything thats left is yours if your interested. just shout!!
I even have a new Dimarzio super distortion (but its F spaced) in creame color.
"I heard using a grinder with a rough pad on is a good way to do contours, is this correct or are there better ways?"
Seems like a grinder with a rough pad would work, but it also seems like it might be more tool than you need. I just finished contouring an RG body using a cheap Black & Decker 5" orbital sander - which is lighter and easier to handle than the grinder I have. I did the rough contours with 80 grit discs, which worked very well and quickly, smoothed them up with 220 then 320, and the contours turned out as smooth as a baby's butt.
The neck profiling is really relevant on an aanj neck where the sides have a different profile. Not necessary on a square heel, but you wil obviously lose the side dots, which you might consider replacing.
As far as body profiling goes I use a combination of belt sander and "Robosander" which is effectively a sanding spindle that fits into a drill chuck. Combined with a pillar drill it is a pretty good combination.
Yea a sander sounds good for the contours, ive got various sanders so il use those.
I did think about the side dots, il see how it is when i play so i may add them later.
Il try out the super distortion to see how that sounds, ive heard they are a hot pickup so im hoping it will be loud! lol
Ive come up against a problem though. I received the locking nut and attached it to the neck. There is a slight gap between the edge of the nut and the end of the fretboard, roughly 1mm, maybe less. The neck is off a 550 and the nut came directly from a 770 so it is compatible. I thought maybe somebody sanded a bit off the end of the fretboard but it doesnt look asif its been tampered with.
What could the problem be? Could this effect the scale length and intonation?
Not so big of a deal though.
see if you can get the nut mounted against the fretboard.
If not your scalelength won't be spot on,but in this case i dont think you will be able to hear it.
Your still able to intonate your guitar propperly.
Related Threads
Ibanez JEM Forum
1.3M posts
69.6K members
Since 2000
