High end knife edge tremolos (chronological order)
Ibanez Edge
Ibanez take on the Floyd Rose. Has a spring lock bar and push in arm. Tuning stability is excellent. 1987(1985 without spring lock bar)
Edge Lo Pro
Has the fine tuners more moved back than the Edge. String lock screw is directly at the saddle. Tuning stability same as OEdge. 1990
Edge Pro: Features sound metal chips at the saddles and can accept ball ends. Lowest profile floating trem. Reduced tuning stability because of the lack of locking studs, with them installed it is on par with Edge/Lo Pro. 2003
Edge Zero
Has the Zps system installed. Switchable to floating trem. Slightly higher profile then the Edge Pro. Features built-in intonation tool. Great tuning stability thanks to locking studs. 2008
Midrange knife edge models chronolgical order (2003 onward)
Edge pro 2
Cheaper version of the Edge Pro. No sound metal chips
Poor tuning stability. Edge Pro, OFR retrofittable 2003
Edge III
Replaced the Edge Pro 2. Features same arm as the EP2
Better tuning stability than the EP2. Edge Pro, OFR retrofittable 2005
Edge Zero II
Best midrange system yet. Features Zps, but no intonation tool. Better Tuning stability than the Edge III. 2011
Ball bearing models
ZR-II
Uses ball bearings as fulcrum points. Features ZPS and built-in intonation tool. Great tuning stability. No wear possible. On S series guitars only. 2005
ZR
Old model of the ZR. Used on middle range S models.
Still great tuning stability. 2003
synchroniZR
Non locking free floating design. Zps-FX system can engage dive-only and fixed bridge mode. Featured on SV models only. 2008
Fixed double locking systems
Fixed Lo Pro
Same as the Lo Pro but as a top mounted fixed bridge 2002
Fixed Edge III
Same as Edge III but as top mounted fixed bridge. (great bridge because the bad knife edges on the Edge III are no problem on this version)
damn... I actually just wrote that....i could have just sent you a link to wikipedia....boredom SUCKS!! glad to help
also:
http://jemsite.com/jem/trems.htm
http://en.wikipedia.org/wiki/Ibanez_Edge
