Please Ignire - trying to figure out why images are not hotlinking anymore - Page 2 - Jemsite
Forum Announcements and Member Help Forum announcements or site news is found here. Members can post calls for help regarding forum/site usage only. Please note this forum is not for disussing forum rules, guidelines and/or moderation.
post #16 of 31 (permalink) Old 01-25-2017, 06:53 PM Thread Starter
Re: Please Ignire - trying to figure out why images are not hotlinking anymore
I never put them in that I remember, but as I look thru image folders, some have them, some don't.
the root folder being "images"? And i don't need the file in any folder that's a sub folder in that root? there are HUUUUGE numbers of folders.
I don't care if everything is hotlinkable [as long as nobody finds pictures of Richele!], I'd prefer it so I never have to worry if I'm going to have images disappear again.
Rich is offline
post #17 of 31 (permalink) Old 01-25-2017, 07:45 PM
site founder 0% owner
jemsite's Avatar
Images is a subfolder right? Delete all the .htaccess files in all subfolder in images for starters.
jemsite is offline
post #18 of 31 (permalink) Old 01-25-2017, 08:13 PM Thread Starter
Technically because it is under public_html, but it is a main folder, like in my pc it is a root folder under ibanezrules only.
I'll save off a copy and experiment a little in this thread just to make sure, but I'm pretty sure you're right. These I never added and somehow appeared in these folders thru all the different hosts I've had over the years.
Rich is offline
post #19 of 31 (permalink) Old 01-26-2017, 11:24 AM
Administrator
shredlikeninja's Avatar
Keep us posted on your progress
~ Glenda
shredlikeninja is offline
post #20 of 31 (permalink) Old 01-26-2017, 01:48 PM
I host things externally on Flickr for the most part to avoid putting stress on our servers for our articles but the pics on the store are all hosted on the site.
Here's one hotlinked:
Stealthtastic is offline
post #21 of 31 (permalink) Old 01-26-2017, 04:09 PM
jemsite's Avatar
public_html is your site root. You can delete or just rename all the .htaccess everywhere except the one in pubic_html.
jemsite is offline
post #22 of 31 (permalink) Old 04-26-2017, 11:41 AM
jemsite's Avatar
Rich your images are failing again at least the folder linked here on the frontpage image
jemsite is offline
post #23 of 31 (permalink) Old 04-26-2017, 11:47 AM Thread Starter
Of course they're not working again, why would they work?! ;/
Test
Rich is offline
post #24 of 31 (permalink) Old 04-26-2017, 11:48 AM Thread Starter
Well, I can see it. YMMV
Rich is offline
post #25 of 31 (permalink) Old 04-26-2017, 12:01 PM
jemsite's Avatar
getting an X (and it stays an X until it's in your cache). Try "in private" browsing.
I recommend you check the hotlink settings for that folder.
jemsite is offline
post #26 of 31 (permalink) Old 04-26-2017, 12:09 PM
jemsite's Avatar
also CTRL+F5 to refresh the page and force new images will yield the X
jemsite is offline
post #27 of 31 (permalink) Old 04-26-2017, 12:15 PM Thread Starter
It had no htaccess file in any of those folders. I even tried adding the file from the folder that does work [first post], and no change.
Rich is offline
post #28 of 31 (permalink) Old 04-26-2017, 03:04 PM
jemsite's Avatar
check htaccess from a parent folder. definitely being blocked.
jemsite is offline
post #29 of 31 (permalink) Old 04-26-2017, 03:07 PM Thread Starter
The pictures in first post are in a folder in the same folder as the one you posted.
Rich is offline
post #30 of 31 (permalink) Old 04-26-2017, 03:36 PM
Administrator
you guys using adblock?
there might be something you need to adjust in that.
Lee
images and links devilsled Off-topic / Miscellaneous 0 05-09-2014 05:50 PM
Watermarking Images. Zoot Off-topic / Miscellaneous 4 12-07-2013 12:59 PM
Images AWOL ? Jem7RB MK Forum Announcements and Member Help 1 06-22-2009 06:58 AM
JS CGI Images Viper-sfm Ibanez JEM, UV, JS & Other Signature Models 26 01-22-2005 09:52 PM
Plz help to figure out equipment!!! - Try to figure pedals! def13suck Gear, Equipment, Recording & Off Topic 5 01-07-2002 05:38 PM
