To "F" space or not to "F" space... - What the "F"... - Jemsite
post #1 of 11 (permalink) Old 05-31-2001, 08:04 PM Thread Starter
I just received a steves special from a friend of mine for a "red lace" project I am working on. It is not F spaced. I have done this in the past but just wanted opinions on putting a regular spaced PU in an RG body....
Thanks
Dave
davenit is offline
post #2 of 11 (permalink) Old 05-31-2001, 08:15 PM
Being that it's a Steve's special, I'll assume it's going in the bridge position.
I had a Duncan in my 560 for a long time. It was not F spaced and I heard no noticable difference in sound.
Go for it....man!!!!
J>
Vaibanez is offline
post #3 of 11 (permalink) Old 05-31-2001, 11:25 PM
Reviews: 3
If you direct-mount the pickup, you can usually balance it out really nicely using a non-F-Spaced pickup. *Good luck.
jay ratkowski is offline
post #4 of 11 (permalink) Old 06-01-2001, 09:49 AM
I don't think it makes any difference...When I bought my S2020 the Ibanez QM bridge pup wasn't F-spaced...You could clearly see that the poles on the pup were not aligned with the strings...
When I changed that pickup, I bought a F-Spaced ToneZone and it aligns perfectly with the strings now..But I am sure it doesnt really change anything for the sound....
my 0.02$...
armadillo is offline
post #5 of 11 (permalink) Old 06-01-2001, 10:07 AM
site founder 0% owner
jemsite's Avatar
asthetics aside, i don't believe you can hear the difference between the F-spaced and std pickups... glen
jemsite is offline
post #6 of 11 (permalink) Old 06-01-2001, 10:18 AM
i agree here too....i never worry about f-spacing....magnetic fields dont just go striaght up....the field looks kinda like a 3 dimensional bell...i guess.....dont sweat it
bluenote is offline
post #7 of 11 (permalink) Old 06-01-2001, 02:10 PM
yup,
linin' 'em up exact aint important at all unless you like things to look just perfick!
If you do then best to get an F spaced bridge and a standard neck (i.e. i find the standard neck lines up better than the F spaced neck)
Steve
ripl3y is offline
post #8 of 11 (permalink) Old 06-01-2001, 02:56 PM
It's not a big deal. *Dimarzio doesn't even make F spaced 7 string pickups. *Anyone notice that?
J Todd Beachler is offline
post #9 of 11 (permalink) Old 06-01-2001, 03:27 PM
One disappointment to me was when everyone made F spaced versions of their already standard pickups, I could notice a difference in the tone that I didn't like. I don't mean regarding the outside strings, I simply mean that when adding width to the coil you get more resistance for the same number of turns, or a smaller coil size for the same amount of resistance. *Seymore Duncan tried saying that his trem spaced pickups had a little more beef to compensate for the thinness of floyd type trems. But I think that was clearly an afterthought of putting the same number of turns on the wider bobbin. With the newer Dimarzio's, a lot of them were designed for the Ibanez crew, so they sound "right" as an F spaced model. *Either way, its no real big deal.
frankfalbo is offline
post #10 of 11 (permalink) Old 06-02-2001, 08:19 AM
good point, frank
bluenote is offline
post #11 of 11 (permalink) Old 08-01-2001, 01:46 PM
thanks for the clarification guys
puppiesonacid is offline
bridge position , bridge pup , spaced pickup , standard neck , string pickup , string pickups
MutationEight by Space Monkey and the Space Monkeys Kilar Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 10-22-2011 11:21 PM
Space Monkey and the Space Monkeys Kilar Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 05-29-2008 07:24 PM
Space Shuttle & Space Station kirk Off-topic / Miscellaneous 28 06-20-2007 11:04 PM
Help on replacing pickups - To F-space or not to F-space? ashlock Archived Topics and Common Questions 10 01-07-2002 06:17 PM
Help on replacing pickups - To F-space or not to F-space? ashlock Ibanez JEM, UV, JS & Other Signature Models 9 03-12-2001 03:51 PM
