Edge 3 tremolo string slip out
My edge 3 tremolo bridge of ibanez rg 370 is getting old. Now a days when i use whammy bar its going out of tune slightly. Also 4th string is slipping out while tuning after restringing. Reason is rust inside the saddle. So i stopped using whammy bar. Blocked the bridge using a wooden block inside. I dont want to replace the bridge. I want to use it like a normal bridge without double locking. I took out the saddle screws and blocks from the saddle and put the strings through the saddle screw hole like an ordinary bridge. I posted this because if anyone experiencing the same problem can try this.
