Edge Tremolo Setup...Help! - Jemsite
post #1 of 2 (permalink) Old 02-01-2012, 10:18 PM Thread Starter
Cool Edge Tremolo Setup...Help!
Whats up guys im new to jemsite and today i just bought my first ever Ibanez Jem7v, its a 2011 model which is back to the original Edge tremolo that Steve Vai still uses to this day.. Ok well what i want/need to know is does Ibanez have these trem's setup correctly? Because my Edge trem seems kinda stiff and it has little flutter effect... pretty stiff... also the Intonation appears done in [email protected]$$ fashion... i checked the intonation at the 12th fret and it wasnt very accurate to the open strings. So i want to know after you buy a Jem do i still need to do a pro-setup? I figured any company that sells guitars over $2,000+ they'd have the factory set them up to a pro-setup standards, string action, intonation, string height, etc, like PRS and Gibson do. So should i just resetup my trem in all phases or is this really the best the factory can do??
Jemini920 is offline
post #2 of 2 (permalink) Old 02-03-2012, 10:37 PM
Re: Edge Tremolo Setup...Help!
Did you buy it straight from the factory? Even a guitar that is perfectly set up and tuned might lose it's perfection in time. There are a lot of factors you know. If you bought it from a store which ordered the guitar then it could be anything from transportation to people touching it at the store.
Xibalba is offline
edge , tremolo - help needed. , tremolo setup guide
Wtb: jem back tremolo cavity plate and edge tremolo arm JemSearcher Classified Ads: Ibanez JEM/UV Guitars 0 01-26-2012 10:17 PM
Is the Edge-Zero II Tremolo a good tremolo system dburn42 All Other Guitars (including Prestige) 6 05-30-2011 10:12 AM
Tremolo setup amt7565 Ibanez JEM, UV, JS & Other Signature Models 5 11-20-2006 08:06 AM
Js1200 Tremolo Setup Help! Stoph Ibanez JEM, UV, JS & Other Signature Models 2 08-11-2005 04:37 PM
Js1200 Tremolo Setup Please Help Stoph Ibanez JEM, UV, JS & Other Signature Models 0 07-14-2005 09:08 PM
