EMGs in an RGA121? - Jemsite
post #1 of 6 (permalink) Old 10-14-2010, 01:12 AM Thread Starter
EMGs in an RGA121?
Just got an RGA121 Prestige Natural finish. I've seen a lot of threads about installing EMGs but can't find any with links and pictures. Got a couple questions for you all who have already done what I am doing.
1. How did you deal with the 5 way switch.
2. How do you adjust the height of the pickups using foam rather than screws?
3. Where did you put the battery?
4. Do you have pix/wiring diagrams?
Thanks for any help!
ryaneise is offline
post #2 of 6 (permalink) Old 10-14-2010, 04:52 AM
Re: EMGs in an RGA121?
They won't fit. The EMG pickups are too square and the route for the pickups in the RGA is too round. You will have to either sand/round off the edges of the EMG or take a dremel tool and open up the route for the pickup on the RGA.. or both.
I'm pissed because I bought EMG 85/60 just for my RGA, and they wouldn't fit.
vultures is offline
post #3 of 6 (permalink) Old 10-14-2010, 06:41 AM
taracatac's Avatar
I used to have them in my RGA321. I sanded the corners of the EMGs. Much better to do that then to modify the body.
taracatac is offline
post #4 of 6 (permalink) Old 10-20-2010, 01:26 PM Thread Starter
Very cool, that helps a lot. Do you know if the output jack that cones with the 121 stock can be used or do I need to buy a new one.
Also, the pickups I'm installing I currently have in my SG, but the don't sound very good, not very hot, can't hit squeels, no crunch. Is that because it's sn SG or could my pickups be bad? Replaced the battery and strings and still just nothing compared to my EC-1000 or even the RGA121 with the stock humbuckers..
ryaneise is offline
post #5 of 6 (permalink) Old 10-20-2010, 11:11 PM
taracatac's Avatar
You can use the stock input jack. I also bought a 3 way switch to replace the 5 way. Sound like your SG has a wiring issue.
post #6 of 6 (permalink) Old 10-30-2010, 01:42 PM Thread Starter
Does anyone have pix of how to wire the stock barrel style output jack?
ryaneise is offline
emg 81 85 , install , rga121
FT: Natural RGA121 Body for Black RGA121 body Maggot Classified Ads: Guitars and Gear 0 09-29-2008 04:24 PM
Installing EMGs in an RGA121 nutbehindthewheel All Other Guitars (including Prestige) 15 09-27-2007 09:24 AM
FT: EMGS MALAM Classified Ads: Guitars and Gear 0 08-28-2006 09:40 PM
Will EMGs fit in the RGA121 without modification??? mityjoeyoungxnj All Other Guitars (including Prestige) 11 01-06-2006 02:28 PM
WTB: EMGs JiMoSiTY Classified Ads: Guitars and Gear 0 05-19-2005 12:40 PM
