How much can I tighten the springs on my 7-string UV777P? - Jemsite
post #1 of 17 (permalink) Old 11-10-2011, 03:38 PM Thread Starter
Iíve changed strings from 9 mm to 10 mm and still tuned it in E.
As you can see the tremolo is way to high up.
Iím a newbie when it comes to Tremolo, and therefore in doubt and afraid of not crashing my new homeboy by pulling the screws too much inside itís body.
Iím also in doubt about if the bar is going too much down to the left side??
a.d.b is offline
post #2 of 17 (permalink) Old 11-10-2011, 03:54 PM
Re: How much can I tighten the springs on my 7-string UV777P?
I play 10s too.
I take the spings out and cut the circle on the claw end off.
Then I bend down the next coil on the spring.
This makes the spring shorter so I don't have to turn the screws in so far.
sebastian is offline
post #3 of 17 (permalink) Old 11-10-2011, 04:05 PM Thread Starter
Hi Sabastian. Is that a common "spring-trick"??
a.d.b is offline
post #4 of 17 (permalink) Old 11-10-2011, 04:12 PM
I don't know???
I just came up with it on my own.
Something had to pull harder or be shorter.
I've done it to at least 20 guitars.
post #5 of 17 (permalink) Old 11-10-2011, 04:14 PM
i would just reconfigure the 3 springs like this
http://www.stratcat.biz/100_7719.jpg
or add a fourth spring
jym-ellis is offline
post #6 of 17 (permalink) Old 11-10-2011, 04:15 PM
The string triangle helps very little with 10s
post #7 of 17 (permalink) Old 11-10-2011, 04:32 PM
IbanezFreak777's Avatar
Reviews: 25
or you could add a 4th spring to help deal with the extra tension
IbanezFreak777 is offline
post #8 of 17 (permalink) Old 11-10-2011, 04:39 PM
If you add more springs, it wont float the same way.
post #9 of 17 (permalink) Old 11-10-2011, 04:45 PM Thread Starter
That is exactly why I have been in doubt, if I should add one.
I’ll try your spring trick, and then I write back.
Wish me luck ;-)
a.d.b is offline
post #10 of 17 (permalink) Old 11-10-2011, 06:29 PM
Reviews: 25
What are you talking about ? I have 5 springs on my USA Custom which rock 12's and it floats perfectly
post #11 of 17 (permalink) Old 11-10-2011, 07:32 PM
It will work with more springs, I know.
It just feels different.
post #12 of 17 (permalink) Old 11-10-2011, 09:45 PM
Reviews: 98
3 springs are fine. Try to learn proper setup techniques. Go to ibanezrules.com/tech
AlaskaBat is offline
post #13 of 17 (permalink) Old 11-10-2011, 10:20 PM Thread Starter
I’ve already been looking in there but I can’t find any explanation for the problem. If you know where it is, then please tell me.
I’ve taking the springs out, and it seems like I need some bad ass tools, that will be able to manage a hardcore spring job.
a.d.b is offline
post #14 of 17 (permalink) Old 11-10-2011, 10:26 PM
Reviews: 98
Originally Posted by a.d.b View Post
Iíve already been looking in there but I canít find any explanation for the problem. If you know where it is, then please tell me.
Iíve taking the springs out, and it seems like I need some bad ass tools, that will be able to manage a hardcore spring job.
http://www.ibanezrules.com/tech/setup/angle.htm
post #15 of 17 (permalink) Old 11-10-2011, 10:52 PM
10 millimeter strings, you say.
dcord is offline
floyd rose , gauge 10 , springs , tremolo bar
RG in D standard: string gauge & springs Mr. Killer Tech: Setup, Repairs and Mods 4 05-08-2011 08:09 PM
How tight should I tighten the string clamps on the trem? fastonebaz Ibanez JEM, UV, JS & Other Signature Models 10 05-15-2009 08:58 AM
10-46 string gauge on my RG1570 - How many springs? badguitarist All Other Guitars (including Prestige) 5 04-06-2008 11:33 AM
Anyone own/play the UV777P and an MM Petrucci 7 string? chris101 Ibanez JEM, UV, JS & Other Signature Models 11 01-13-2007 07:09 PM
7 string string gaug change and springs Raffel All Other Guitars (including Prestige) 16 04-26-2003 04:12 AM
