Is the Lo-Pro a direct replacement for the Edge cavity wise? - Jemsite
post #1 of 12 (permalink) Old 04-03-2001, 07:10 PM Thread Starter
This should a simple question...
Can I just replace the Edge trems on older Jems (Like FPs) for a Lo-Pro without any routing?
Thanks.
dacmo is offline
post #2 of 12 (permalink) Old 04-03-2001, 07:48 PM
My JemFP came with an Edge in it, and I slapped a Lo Pro in there with no issues.
tomizm is offline
post #3 of 12 (permalink) Old 04-03-2001, 07:56 PM Thread Starter
Cool... Thanks
dacmo is offline
post #4 of 12 (permalink) Old 04-03-2001, 08:17 PM
kirk's Avatar
The only difference is the length of the route. *It's longer on Edge equipped guitars.
But - they will direct swap, just like tomizm said!
kirk is offline
post #5 of 12 (permalink) Old 04-04-2001, 01:04 AM
One other thing you might want to look out for is the difference in length of the ( I'm not sure of the tech name) Transfer bar - the wide flat bar that sets between the top of the trem and the springs....
See pick below of one taken off another Edge Lo-Pro against the Edge Lo-Pro I have been saving for a project and there are considerable differences in length...
Project Guitar is offline
post #6 of 12 (permalink) Old 04-04-2001, 01:11 AM
site founder 0% owner
jemsite's Avatar
the longer base is from a non-recessed Edge. Seen on '86 and earlier Ibanez'. No LoPros should come that way... glen
jemsite is offline
post #7 of 12 (permalink) Old 04-04-2001, 01:35 AM
Hummmmmm...
Somebody probably performed surgery on it before I got then since the top is a standard Lo Pro Edge....
post #8 of 12 (permalink) Old 04-04-2001, 01:37 AM
jemsite's Avatar
the longer base will typically protrude beyond the tremolo cover in a standard RG/S body... glen
jemsite is offline
post #9 of 12 (permalink) Old 12-06-2002, 05:35 PM
yes direct swap
hyesac is offline
post #10 of 12 (permalink) Old 02-02-2004, 01:32 PM
Anyone know how much work this mod will take? I wrecked my edge trem on my RG570 so im really considering a Lo Pro ( there is no difference between Lo Pro and Lo Pro Edge, right? ).
It it just a case of taking off the springs, assembling the trem then putting it on the studs already there?
Thanks for any help guys
Cassius is offline
post #11 of 12 (permalink) Old 02-02-2004, 01:34 PM
jemsite's Avatar
the edge and lopro edge are 100% interchangeable ...glen
jemsite is offline
post #12 of 12 (permalink) Old 02-02-2004, 01:35 PM
Pull the trem with the strings on
http://www.ibanezrules.com/tech/setup/remove.htm
Pull the strings off the edge and stick them in the "whatever". Reinstall.
Rich is offline
edge trem , edge trems , equipped guitar , pro edge
direct lo-TRS replacement ? mugatu All Other Guitars (including Prestige) 16 01-18-2016 06:47 AM
ZR direct replacement arm holder lcsdds All Other Guitars (including Prestige) 3 10-03-2007 06:22 PM
Mesa 50/50 powering a bass rig - wise or un-wise idea? tomizm Gear, Equipment, Recording & Off Topic 2 06-21-2001 01:08 AM
Is the Lo-Pro a direct replacement for the Edge cavity wise? dacmo Tech: Setup, Repairs and Mods 7 04-04-2001 01:37 AM
