Metal guitar style vibrato. - Jemsite
post #1 of 7 (permalink) Old 07-29-2010, 11:34 PM Thread Starter
When I listen to people like Zakk Wylde and Adrian Smith, I can hear a really wide, slow and even vibrato. Do things like string gauge, guitar style, and neck width affect this? Because a lot of people associate fixed bridge guitars like Gibsons with that. Does anyone else use this vibrato? Because with my RG, with its very thin neck, after I finish a fast passage, I instinctually use a quick vibrato. Any comments here?
JordanRG is offline
post #2 of 7 (permalink) Old 07-30-2010, 12:10 AM
Reviews: 98
Re: Metal guitar style vibrato.
No, no, no, and no! Vibrato comes from your fingers and wrist-not string gauge, neck width, etc. Go watch the George Lynch Guitar Bible, as he shows some great vibato techniques including the infamous jack-off vibrato.
AlaskaBat is offline
post #3 of 7 (permalink) Old 07-30-2010, 05:03 AM
While vibrato does come from your hands.There are things that can help you get that wide zakk wylde type vibrato.One is tuning down so the strings are looser and have less tension that makes it easier to vibrate the strings.Shorter scale lengths usually have less tension with similiar string gauges.A ton of gain helps too. Zakk also often uses a wah pedal as well.On recordings sometimes that wild vibrato is overdubbed in. Adding artificial harmonics and vibrating those also helps for that over the top vibrato style. Good luck with it. Super humanly strong fingers and callouses like granite never hurt either check out stevie ray vaughn bending and vibratoing his 13's on a strat sometime.
corpraider69 is offline
post #4 of 7 (permalink) Old 07-30-2010, 05:24 AM
Just practice slow even bends, then build up speed. You can do it with any gauge strings you just need to practice, maybe try with a metronome on really slow?
guitarnoize is offline
post #5 of 7 (permalink) Old 11-19-2010, 04:44 PM
John Sykes is know for his amazing vibrato.
1badsteed is offline
post #6 of 7 (permalink) Old 11-19-2010, 05:52 PM
Reviews: 98
...so how does that little nugget of info shed light on the OP?
post #7 of 7 (permalink) Old 11-19-2010, 06:45 PM
A little thing called assumption, which is the mother of all screw ups. I assumed that the person interested in vibrato technique would go to Youtube and look up John Sykes, watching his playing technique. Perhaps I should have spelled that out for people that do not know. Nugget defined...
JordanRG, go to youtube and type in vibrato technique. Or look up JOHN SYKES vibrato technique.
Vivien Campbell sometimes frets a note, then presses down on the string above the nut between the tuning pegs to create vibrato.
Other than that, the replies above pretty much cover vibrato.
gibson , iron maiden , vibrato
Vai-meets-Petrucci style guitar album on iTunes + my guitar exercises JonasTamas Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 07-15-2009 04:46 PM
Improvisation On A Metal Style Backing Track Jem7 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 6 02-22-2008 07:27 PM
WTB: RG style h/s/h guitar fromchicagowithlove Classified Ads: Guitars and Gear 1 03-16-2006 11:56 PM
What is this s-style guitar? gkelm Vendors, Auction & Reseller Talk 0 02-16-2004 03:22 PM
nashville style guitar Bar_Hook Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 11-19-2003 02:28 PM
