Perfect intonation... HIGHER FRETS ARE FLAT!!! - Jemsite
post #1 of 7 (permalink) Old 11-17-2011, 05:52 PM Thread Starter
I never really noticed this before but I noticed that my RG350DX's higher notes (frets 15-24) sounded a little flat. I played them into a chromatic tuner and sure enough, the notes appear flat. How can this be possible? The only thing I can come up with is bad fret spacing which I hope is not the case because that means I have to buy a new neck. Please reply...
AND yes, I put the strings in PERFECT intonation.
ShortFingeredShredder is offline
post #2 of 7 (permalink) Old 11-17-2011, 06:45 PM
Re: Perfect intonation... HIGHER FRETS ARE FLAT!!!
is the neck possibly bowed somewhere?! not necessarily a good idea, but an idea nonetheless!
rickybaby1985 is offline
post #3 of 7 (permalink) Old 11-17-2011, 07:49 PM
try pressing a little harder when you fret.
jym-ellis is offline
post #4 of 7 (permalink) Old 11-17-2011, 07:57 PM
I had the same thing happen on the same guitar but it was only on 1 string. I had to move the G strings saddle way back as far as I could get it to correct it. the saddle looks like its barely hanging on there, but I haven't had any problems since. Sounds like you need a set up to me??
GUITARMAGEDDON is offline
post #5 of 7 (permalink) Old 11-18-2011, 06:50 AM
Checked your intonation?
Death.by.G-string is offline
post #6 of 7 (permalink) Old 11-18-2011, 07:13 AM
I seriously doubt your fret spacing is off. I'd try intonating your strings to the 24th fret.
PERFECT intonation on every fret isn't possible. You can get it close, but there is no way to get every note on every string to be in PERFECT pitch. That's why they call guitars a "compensated" tuning system. You have to compensate for variations.
A wide number of variables can affect how accurate your intonation is, including string thickness, fret wear, string height, bridge angle, finger pressure, etc. You're going to just have to try intonating your strings in a way that better compensates for that adjustment.
dcord is offline
post #7 of 7 (permalink) Old 11-18-2011, 09:14 AM
That is what I was thinking too. There are always slight variations.
sssteve72 is offline
intonation , neck , saddles , truss rod
Elusive perfect intonation.. metalguy Tech: Setup, Repairs and Mods 1 09-06-2011 09:57 AM
"weak" sloppy sound on higher frets, JS100 mag8 Ibanez JEM, UV, JS & Other Signature Models 7 03-18-2011 05:37 PM
Which models had 22 frets and a flat headstock? peter762033 All Other Guitars (including Prestige) 2 03-05-2010 08:21 PM
Choked strings on higher frets LwiGuitars Tech: Setup, Repairs and Mods 6 06-06-2005 05:44 PM
Scalloping Frets - Smoothening out those higher frets siliconsurf Tech: Setup, Repairs and Mods 22 03-25-2003 07:17 AM
