Re-setting Neck - my ibanez neck is slightly off alignment - Jemsite
post #1 of 3 (permalink) Old 09-06-2001, 11:56 PM Thread Starter
Does anyone have suggestions for resetting a mis-aligned neck? The high 'E' is falling off. I've installed kit necks before but not one with holes already drilled. I have considered drilling out the old holes and installing dowel plugs. But I'm looking for something less radical, like filling the old screw holes? With what? BTW, the guitar is new, purchased form Musicians Friend for cheap. It's just for gigs, so I can beat on it. It's under warranty but sending it back to MF then to Hoshino & a month or 2 later getting it back doesn't thrill me. Any ideas would be helpful, thanks.
CrossingStar is offline
post #2 of 3 (permalink) Old 09-07-2001, 12:02 AM
site founder 0% owner
jemsite's Avatar
Re-setting Neck
make sure the NUT is centered first. Assuming the high-E is off by the upper fretboard... there is often some play in the pocket where it can torque causing this. I would first try to loosen the neck screws (4) a half-turn or so. looking at the neck joint (rear body) you will move the neck so to eliminate the problem, then retighten the screws. If the pocket is cut right and stable, it should hold.
ALternately you could stand the body on edge (lower horn to body) and use leverage to position the neck as you tighten it. It is easier than it sounds here. Anyways try that before redrilling. It is a rarity the neck/body is drilled wrong... glen
jemsite is offline
post #3 of 3 (permalink) Old 09-07-2001, 04:00 PM Thread Starter
Re-setting Neck
Thanks Glen, I'll give that a try. The nut is centered, it's more off near the body.
neck joint , neck screws , upper fret
Neck alignment. Sefrez All Other Guitars (including Prestige) 2 01-07-2012 06:43 AM
neck alignment / nut alignment alt12345 Tech: Setup, Repairs and Mods 0 08-20-2009 02:37 AM
Can a shim be used to correct neck alignment? Max Dread Tech: Setup, Repairs and Mods 1 06-02-2009 09:17 AM
Neck Alignment RG1570 phil27 Tech: Setup, Repairs and Mods 10 01-21-2007 01:23 AM
Bad neck/string alignment: need advice stratoskier Tech: Setup, Repairs and Mods 3 06-19-2005 07:01 PM
