replacing a trs2 w/ an OFR - ...can i do it? - Jemsite
post #1 of 12 (permalink) Old 03-15-2001, 12:51 AM Thread Starter
an Original Floyd Rose can directly replace a Lo-Trs II, right? *i thought i remembered seeing this somewhere. *i know the edge doesn't fit w/out some routing... *
ShredHead42 is offline
post #2 of 12 (permalink) Old 03-15-2001, 01:29 AM
I've replaced my TRSII with a Licensed one from WD. It should the same for the OFR. Should be a direct replacement. Only thing is you want to check the what the trem block looks like.. might need to get rid of some wood on the sides.
dacmo is offline
post #3 of 12 (permalink) Old 03-15-2001, 02:01 AM
You should not need to remove any wood, just throw it in.
Noodles is offline
post #4 of 12 (permalink) Old 03-15-2001, 02:47 AM
Noodles.. it depends on which company manufactured the floyd, right? Mine had the block rubbing against the side on my RG. I think that some manufactures may not have this problem.
dacmo is offline
post #5 of 12 (permalink) Old 03-15-2001, 04:54 AM
Only licensed floyds very(ex. edge vs. trs) but correct me if I'm wrong their is only one version of the ofr hense "original".
Noodles is offline
post #6 of 12 (permalink) Old 03-15-2001, 12:52 PM
site founder 0% owner
jemsite's Avatar
It should fit directly. That said, I would confirm a return policy on the new tremolo in case there is a slight incompatability and it doesn't fit perfectly... glen
jemsite is offline
post #7 of 12 (permalink) Old 03-15-2001, 09:07 PM Thread Starter
ok, thanks. * they offer original floyds from carvin too, but i'll check out WD and see who has the lowest price. * * i was also thinking ebay, but then there's that return policy... * * *i'm also not sure if it's worth $160, or if i should just sell this guitar and buy an RG5XX. *
post #8 of 12 (permalink) Old 03-18-2001, 05:23 AM
Go for the RG by the time you throw in the trem and then probably something else you will have upgraded to an RG price range anyway.....
Project Guitar is offline
post #9 of 12 (permalink) Old 03-19-2001, 01:43 PM
Reviews: 5
If you're also a JEM player, I'd recommend keeping it and tossing in the OFR. *I did this to my RG450. *I like the RG-450s better because the neck profile is very similar to the JEM moreso than the Wizard on the 5xx. *So I just tossed in the OFR I had in an old guitar and plays great and looks even better. *Chrome is so much cooler looking on a blue guitar than black.
jem7vwh is offline
post #10 of 12 (permalink) Old 06-27-2002, 10:21 PM
TRS and edge tremolos are japanese and korean, so their messurements and specs are all in metric. Floyds are american so their specs are in imperial. The specs are slightly different. I suppose you could switch, the difference (width and whatnot) would be slight but it is enough to throw the intonation out a little. So I say switch to an edge.
Replace parts for an ibanez is a bitch because most companies that sell individual parts are american and so it won't quite fit onto metric Ibanez'.
The Madness Here is offline
post #11 of 12 (permalink) Old 08-19-2002, 12:14 PM
Just keep your TRS-2 and get a Tremsetter (whichs comes on the jem7v) and keep your cost down to $50. lol
IbanezJPM is offline
post #12 of 12 (permalink) Old 09-01-2003, 06:33 PM
Hi guyz
I am a newbie in this page, I mean I have just registered here. This page is cool a lot specially 'cuz tons of people know a lot here about guitar setup and maintenance, and you can make your own lutherie in your home just thanks to the aid of people around here....
That's why I am here, I have a little (big) problem. I have a RG 470, with a Lo-Trs tremolo since just a year and my tremolo knives have lost its superficial hardener material. In other words, my tremolo goes out of tune after every touch on the tremolo bar.
I have some questions for you, I hope you can solve this problem, 'cuz I am trying sum solutions, but there are not very nice (for example, applying Teflon to the pivot studs, it slightly works but tone losing is still there, and the solution is cool just for a week....). I want to know if I can repair the knives, and how to do it. Is there some kinda paint or enamel to use on it? Or a temper on the base plate must be done?
Either having or not any solution, I have another question: if I ever want to change my tremolo for a Floyd Rose, I have been reading here in jemsite I can change Lo-Trs for an Original FR or into a Floyd Rose Pro without making any changes. Is this information right? You know, I don't live in U.S.A. (I live in Spain), so the Floyd Rose tremolo systems have kinda higher prices here, so I don't want to take a bad step. And I read here that Floyd Roses have a defect in their design, which makes knives to be crushed earlier than Ibanez Edge for example. Does it mean that Floyd Rose tremolos are not worthy? And what are the differences between an Original and the Pro Floyd Rose?? Which one is recommended to fit my Lo-Trs?
Please, answer me here or to [email protected], thank you very much!
Kpullowan
kpullowan is offline
base plate , edge trem , floyd rose , floyd rose pro , floyd rose trem , floyd rose tremolo , trem block , tremolo bar , tremolo system
Early 90's S470 - Replacing lo-trs2 - Nut size? W0MB13 All Other Guitars (including Prestige) 1 02-22-2011 10:21 PM
Dealing with cosmos hardware and the TRS2 thedonutman Tech: Setup, Repairs and Mods 3 09-28-2009 12:55 PM
retrofit trs2 (dont kill me) xeroparadox All Other Guitars (including Prestige) 7 02-21-2007 04:52 PM
Will an orgi. edge fit in Lo trs2 cavity - HELP.. Im very cu seahawk2982 Tech: Setup, Repairs and Mods 2 08-01-2001 11:10 AM
replacing a trs2 w/ an OFR - ...can i do it? ShredHead42 Tech: Setup, Repairs and Mods 8 03-19-2001 01:43 PM
