Re: auto advice: buyin a truck
well i got them to 21376 out the door on the 1500. here are the specs. I think i might take it
32 Gallon Fuel Tank
40/20/40 Split Bench Seat
Bright Front Bumper
Bright Rear Bumper
Carpet Floor Covering
Chrome Appearance Group
Class IV Receiver Hitch
Cloth 40/20/40 Bench Seat
Electronically Controlled Throttle
Engine: 5.7L V8 HEMI MDS VVT
Federal Emissions
Front & Rear Floor Mats
Heavy Duty Engine Cooling
Heavy Duty Transmission Oil Cooler
Hemi Badge
Next Generation Engine Controller
Quick Order Package 26A ST
Rear Folding Seat
SIRIUS Satellite Radio
ST Popular Equipment Group
Speed Control
Tip Start
Transmission: 5-Speed Automatic
↑ to top
Features
ENTERTAINMENT FEATURES
Speakers: 6
CD player
Radio data system
MP3 decoder
AM/FM radio
SEATS AND TRIM
Front seats: bench
Front center armrest: w/storage
Rear seats: bench
Max seating capacity: 6
WARRANTY
Corrosion perforation warranty: 60 months/100,000miles
Basic warranty: 36 months/36,000miles
Roadside assistance coverage: 36 months/36,000miles
Powertrain warranty: 60 months/100,000miles
CONVENIENCE FEATURES
Power windows
Front beverage holders
Passenger door bin
Speed control
1-touch up
Driver door bin
Air conditioning
1-touch down
Tilt steering wheel
BODY EXTERIOR
Power door mirrors
Left rear passenger door: conventional
Rear step bumper
Trailer hitch receiver
Bumpers: chrome
Heated door mirrors
Right rear passenger: conventional
LIGHTING, VISIBILITY AND INSTRUMENTATION
Low tire pressure warning
Delay-off headlights
Variably intermittent wipers
Voltmeter
Fully automatic headlights
Oil pressure gauge
Tachometer
SAFETY AND SECURITY
Brake assist
Overhead airbag
Ignition disable
Electronic stability
Dual front impact airbags
ABS brakes
4 wheel disc brakes
Traction control
↑ to top
Tech Specs
POWERTRAIN
Cylinder deactivation
Engine liters: 5.7
Cylinder configuration: V-8
Variable valve control
Fuel economy highway: 20mpg
Manual-shift auto
Sequential multi-point fuel injection
Variable intake manifold
Number of valves: 16
Transmission: multi-speed automatic
Horsepower: 390hp @ 5,600RPM
Fuel economy city: 14mpg
Fuel tank capacity: 32.0gal.
Drive type: rear-wheel
Engine location: front
Mode select transmission
SUSPENSION/HANDLING
Rear anti-roll bar
Power steering
Front anti-roll bar
Front wheel independent suspension
Wheel size: 17"
SPECS AND DIMENSIONS
Curb weight: 2,214kg (4,881lbs)
Exterior body width: 2,017mm (79.4")
Exterior length: 5,817mm (229.0")
Greenhouse Gas Score (GG): 1
Payload: 735kg (1,620lbs)
GVWR: 3,039kg (6,700lbs)
Rear hiproom: 1,598mm (62.9")
Compression ratio: 10.50 to 1
Engine horsepower: 390hp @ 5,600RPM
Rear legroom: 881mm (34.7")
Engine displacement: 5.7 L
Rear headroom: 1,008mm (39.7")
Passenger volume: 3,302L (116.6 cu.ft.)
Exterior height: 1,908mm (75.1")
Wheelbase: 3,556mm (140.0")
Front legroom: 1,041mm (41.0")
Rear shoulder room: 1,669mm (65.7")
Engine bore x stroke: 99.6mm x 90.9mm (3.92" x 3.58")
Turning radius: 6.9m (22.6')6.9 '
Front shoulder room: 1,676mm (66.0")
Front hiproom: 1,605mm (63.2")
Air Pollution Score (AP): 6
Towing capacity: 3,969kg (8,750lbs)
Front headroom: 1,041mm (41.0")
OFF-ROAD CAPABILITY
Approach angle: 17 deg
Ground clearance (min): 229mm (9.0")
Departure angle: 25 deg
Ramp breakover angle: 21 deg
Ground clearance (max): 244mm (9.6")
