Building a small supercomputer - Jemsite
post #1 of 26 (permalink) Old 12-11-2006, 01:24 PM Thread Starter
Hey folks,
I have a just built a (6CPU (24 core) 24Gb RAM) mini cluster (6 X Intel qx6700 chips). Im currently running OSCAR over fedora core 6 but would like to implement a single system image package ontop of this. openSSI looks great but their linux 2.6 kernel version is still in development. Hardware prevents me from using the 2.4 kernel (I think). Anyways I was going to use MOSIX and was wondering if anyone here has any experience in this sort of thing?
its a long shot... but there are alot of computer guys on this site
Devo is offline
post #2 of 26 (permalink) Old 12-11-2006, 01:29 PM
Re: Building a small supercomputer
Will it be able to run Minesweeper?
The Euphor is offline
post #3 of 26 (permalink) Old 12-11-2006, 01:52 PM
jaxadam's Avatar
Or Freecell?
jaxadam is offline
post #4 of 26 (permalink) Old 12-11-2006, 02:19 PM Thread Starter
hmmmm ... i dunno... I was just gonna use it to play tetris... work on getting my reaction times down
Devo is offline
post #5 of 26 (permalink) Old 12-11-2006, 02:24 PM
Gonna be simulating a lot of galaxy formations are we?
Turn it into a SETI Machine....
Lefty Robb is offline
post #6 of 26 (permalink) Old 12-11-2006, 02:26 PM
wait... 6 quad core extreme's!!!! did u pay like 10k for this thing? what mobo is there that even fits 6 processors?
newbieguitarmaker is offline
post #7 of 26 (permalink) Old 12-11-2006, 02:38 PM
"Let me put it this way, Mr. Amor. The 9000 series is the most reliable computer ever made. No 9000 computer has ever made a mistake or distorted information. We are all, by any practical definition of the words, foolproof and incapable of error."
Reaper is offline
post #8 of 26 (permalink) Old 12-11-2006, 03:21 PM
i used to have that as my screen saver
screamndemon69 is offline
post #9 of 26 (permalink) Old 12-11-2006, 03:23 PM
HAL eh?
that name came from one letter away from each letter in IBM.
post #10 of 26 (permalink) Old 12-11-2006, 03:53 PM
I doubt it tracked the gravity affects of every star and black hole on its motion through billions of years giving the true representation of the evolution of a galaxy in the universe, including that of its affects on nearby and even collisions of other galaxies into it.
http://www.cita.utoronto.ca/~dubinski/nbody/
post #11 of 26 (permalink) Old 12-11-2006, 03:56 PM
Are you running it with Compiz or Beryl?
Regards
André
fettouhi is offline
post #12 of 26 (permalink) Old 12-11-2006, 03:59 PM
How many Gflops can this thing do?
post #13 of 26 (permalink) Old 12-11-2006, 04:07 PM
Sabre's Avatar
How much money you got man?! Quad Cores!
Sabre is offline
post #14 of 26 (permalink) Old 12-11-2006, 04:22 PM
I have set up a mosix cluster once upon a time, ages ago, maybe 1999?, just for fun. Don't recall too many details though, so I doubt I can be much help. I don't recall it being difficult though.
Also messed around with the SCO Unixware based Compaq/Tandem NonStop clusters, a single-system-image clustering thing mostly used by telcos a little bit -- was right across from the guys demoing it at SCO forum in 2000, iirc. (Wow, SCO went into a tailspin, eh?) I think they used a proprietary interconnect -- Servernet, were moving to infiniband, or something. Not sure what's going on with it now, but, iirc, some of the same guys that worked on the NonStop clustering stuff went on to work on the open source SSI stuff.
IIRC, most of these clustering systems, even the SSI ones have the problem that sockets don't migrate, so if you migrate a process from one machine to another, the network connections which that process are using remain routed through the original NIC in the original host, and it's a bit of a hard problem due to the way internet routing works, iirc. (e.g. Auspex NFS servers solved a similar problem by having special network hardware, iirc.) But it's been years since I last looked at this stuff, so maybe they've figured something out.
Depending on your application, it may not be a concern.
Ferrous Lepidoptera is offline
post #15 of 26 (permalink) Old 12-11-2006, 04:25 PM
HAL eh?
Interesting... you learn something new every day.
Reaper is offline
Building a JEM RPG by RafaPG rafapg Ibanez JEM, UV, JS & Other Signature Models 88 01-13-2014 05:48 PM
cheap, small, and tube Praetorian Gear, Equipment, Recording & Off Topic 5 11-08-2005 09:01 PM
Small Midi Foot Controller... NickFlyMan Gear, Equipment, Recording & Off Topic 6 04-30-2003 07:38 AM
Small side dots on any other Jem other than DBK lhrocker Ibanez JEM, UV, JS & Other Signature Models 17 07-04-2002 08:34 AM
Best small clean practice amp - Solid state, good clean tone Kremlin Gear, Equipment, Recording & Off Topic 9 04-09-2002 11:03 PM
