Flat Monitors - Jemsite
post #1 of 15 (permalink) Old 01-01-2007, 09:42 AM Thread Starter
Flat Monitors
Happy new year guys.
Well, got some good info on processors and graphics etcf, rom you guys, but the other thing I'm thinking of is the monitor.
For recording in my room, I'm going to have to move away from CRT, due to the induced noise. Now, we know that CRT pretty much gives the best colour, the best picture, but TFT or LCD must have come a long way by now, so what are the specs that I need to look for on a 19" or larger TFT or LCD to attempt to match the quality of a CRT? Some screens a while ago, I had noticed were nowhere as good as a CRT.
So far I've studied the mS times and dot pitch, but what else do I need to look for to get a good image?
Thanks
Ant1981 is offline
post #2 of 15 (permalink) Old 01-01-2007, 09:53 AM
Re: Flat Monitors
If you talk to a graphic expert about CRTs they call some CRT monitors 'over bright', usually meaning you have to have the brightness set to 10 - 20% to get a true black, it is impossible to get a true black on any LCD because they are all so overbright. This makes them useless for photo editing or desing but for recording, you dont need a really good monitor and the radiation factor is probably worth getting an LCD.
Ive settled for a LCD even tho I study design and am a gamer because the monitors I have to use at uni are LCDs so its more important that my desings look the same here and at uni than having them look good just at home, the markers use LCDs as well so it is really important.
If you were getting dual monitors then maybe get one of each, one for recording and one for gaming.
crevis is offline
post #3 of 15 (permalink) Old 01-01-2007, 10:19 AM
Re: Flat Monitors
Try here for some high end lcd's if thats what your looking for. http://www.lacie.com/ I think the typical LCD blows away the typical CRT in every way. Maybe for super critical colour rendition the best CRTs are still tops but that doesn't realy apply to most users.
Rotti is offline
post #4 of 15 (permalink) Old 01-01-2007, 11:22 AM
Re: Flat Monitors
I agree, for 99% of PC users convience is the top priority.
crevis is offline
post #5 of 15 (permalink) Old 01-01-2007, 11:31 AM Thread Starter
Re: Flat Monitors
My PC is used for even photo editing aswell as music and office apps, so I would like to get the best quality that I can in terms of image and colour capabilities.
I currently have an old NEC Multisync 6FG, which is a 21" CRT, great when it was new, but in recent times, the image is dropping off as the tube is ageing, also of course being CRT, induces noise into pickups and mics, hence the search for LCD or TFT...
...have just been looking at the NEC MultiSync 90GX2, MultiSync 1990FX and MultiSync LCD 1990SXi. All 19" flat panels, although a significant price difference between each model, I've yet to establish the actual difference in image quality between them all and what they can offer me.
Ant1981 is offline
post #6 of 15 (permalink) Old 01-01-2007, 11:57 AM
Re: Flat Monitors
Do they even make CRTs anymore?
Rotti is offline
post #7 of 15 (permalink) Old 01-01-2007, 12:02 PM Thread Starter
Re: Flat Monitors
I think they do, my dad says extreme high end users where he works (national newspaper) use top notch CRT's due to the colour correction for DTP, page, image setting etc.
Ant1981 is offline
post #8 of 15 (permalink) Old 01-01-2007, 12:07 PM
site founder 0% owner
jemsite's Avatar
Re: Flat Monitors
i'd skip 19" lcd and go to 21-22" as they offer much higher resolution and hence more desktop space and a finer pixel pitch. these will crush your CRT, which you can visbly see drop off which means it's worse than you even realize. search a similar thread for discussion of LCDs that size.
unless you're programming or doing something where you want a dedicated monitor to one application, i'd also go with one larger LCDs over two smaller ones (ie. one 24" vs two 19"s or two 21"s)... glen
jemsite is offline
post #9 of 15 (permalink) Old 01-01-2007, 12:25 PM Thread Starter
Re: Flat Monitors
I'm not sure how another inch or two will give me alot more, but I noticed the significant jump in price for the extra inch, also the response time seems to get a little slower on them too. But say for cubase, wouldn't the two 19's still be better than one 24" due to horizontal scrolling along the time line?
Ant1981 is offline
post #10 of 15 (permalink) Old 01-01-2007, 12:53 PM
jemsite's Avatar
Re: Flat Monitors
check the other similar thread for actual resolutions. i wouldn't do 2x19 the minimum would be 2x20 due to resolution per panel (1440x900 vs 1680x1050). this comes with using both 24" and 19"... glen
jemsite is offline
post #11 of 15 (permalink) Old 01-01-2007, 01:20 PM Thread Starter
Re: Flat Monitors
Cool, I'll have a go at finding that thread, but, however, if I go up a size, it's almost double the price
Ant1981 is offline
post #12 of 15 (permalink) Old 01-01-2007, 01:44 PM
Re: Flat Monitors
Yeah, thats for sure.
As soon as you go above 21" the prices start to double and go crazy. You should be able to find a quality, well-priced 20" or 21" around though.
the.godfather is offline
post #13 of 15 (permalink) Old 01-01-2007, 01:53 PM Thread Starter
Re: Flat Monitors
Even a 20" or 21" is double the cost of the 19" though, crazy. I need to really assess if that extra res is worth my money.
Ant1981 is offline
post #14 of 15 (permalink) Old 01-01-2007, 08:52 PM
Re: Flat Monitors
It's worth it. If you go widescreen you will see a BIG difference between a 19" and a 22" or 24". In the store it's hard to judge but when you setup your 22 or 24 inch flat screen monitor at home you'll be amazed at how nice it is. I think 22" widescreen will soon become the new standard. There are some good deals out there too.
Rotti is offline
post #15 of 15 (permalink) Old 01-01-2007, 11:35 PM
Re: Flat Monitors
I think mac are the only ones that make them now but theres probably alot left in stock around the place. If you look on a few site you'll eventually find someone with some left overs.
crevis is offline
Flat neck guitars marino Tech: Setup, Repairs and Mods 2 11-24-2005 10:38 AM
"Tuning" a PA system to be flat -- how-to?? bduersch Gear, Equipment, Recording & Off Topic 2 12-06-2004 04:49 PM
Studio Monitors RSVampire Gear, Equipment, Recording & Off Topic 10 05-28-2003 04:31 PM
