Help with Windows problem (not burning CDs) - Jemsite
post #1 of 18 (permalink) Old 12-16-2006, 03:22 AM Thread Starter
I don't know what happened, heres a pic
http://img204.imageshack.us/img204/3109/burnzq1.jpg
it says I don't have a burner and that I need to connect one
any help?
ZOMB13 is offline
post #2 of 18 (permalink) Old 12-16-2006, 03:53 AM
Sabre's Avatar
Re: Help with Windows problem (not burning CDs)
Yeah, have you got a CD-RW?
Sabre is offline
post #3 of 18 (permalink) Old 12-16-2006, 03:28 PM Thread Starter
yeah, my computer is a HP pavilion a720n from late 2005, it has a dvd writer shared with a normal cd writer drive and the standard cd-rom drive, I was able to burn cds and dvds when I got it up to the point where I installed these programs windows media 11, intermedia dvd creator and dvd lab pro, after that I could not burn anything, since it said I needed to hookup a burning device.
ZOMB13 is offline
post #4 of 18 (permalink) Old 12-18-2006, 02:00 AM Thread Starter
Any help someone?
ZOMB13 is offline
post #5 of 18 (permalink) Old 12-18-2006, 02:25 AM
Sabre's Avatar
I think you may have to re-install the drivers then, go on HP's website or you may be able to do it via the add hardware wizard.
Sabre is offline
post #6 of 18 (permalink) Old 12-18-2006, 02:48 AM
Yeah, thats the first thing you should try in a situation like this.
crevis is offline
post #7 of 18 (permalink) Old 12-18-2006, 09:10 PM Thread Starter
I updated the driver, still windows media player won't acknowledge I have a burner, and I noticed this too
http://img214.imageshack.us/my.php?image=kaldhq2.jpg
I think im going to have to take it to a tech and pay the huge fee....
ZOMB13 is offline
post #8 of 18 (permalink) Old 12-18-2006, 09:22 PM
site founder 0% owner
jemsite's Avatar
did it work before? if so...
turn off the PC and unplug the drive (two cords - one 4 prong power and one the IDE connector)
then power back on (no drive)
then shutdown and plug the drive back in... upon boot that might recognize the drive.
last resort is google the drive and update the firmware... you could also always try burning with nero to see if it's a software issue... glen
jemsite is offline
post #9 of 18 (permalink) Old 12-18-2006, 09:37 PM
I think before unplugging and all that it may make sense to see if the drive is being recognized upon pc start, it should show up as part of the DOS window when you start your PC. If you know how to get into your PC's Bios you can also check there. If it doesn't show up there check if all wires are con nected, to the drive as well as the motherboard. If it still doesn't show you can see if you can connect it to a different IDE port (you should have 2). I assume its a normal IDE drive? If it still doesn't show its most likely the drive itself. Also have a look if it still shows under the drives within windows. If it does and works fine there its most likely the software you burn with, if it doesn't and all wires are good its most likely the drive.
dragsternj is offline
post #10 of 18 (permalink) Old 12-18-2006, 09:50 PM
I'd have to be extremely desperate to go to a tech. Theres no problem a tech can fix that you cant.
If the drive shows up in the hardware manager in control panal, then its definately software, all the components of media player are plugins and most come with nero. Nero comes with all the MP plugins and codecs and when I have a problem like this reinstalling nero or another plugin pack will fix it.
Just keep crossing all these suggestions off your list and if all fails, THEN go to a tech.
crevis is offline
post #11 of 18 (permalink) Old 12-18-2006, 10:32 PM Thread Starter
About the wiring, the burner came with the pc, so I think the wires are connected and haven't moved on its own, the computer does recognize I have a burner, but sometimes it shows it as CD Drive, only Windows refuses to recognize I have a burner, im guessing WMP 11 did something to it, as I could burn stuff with WMP 10.
EDIT:
I just burned some CDs with Sonic Record Now, seems WMP 11 is the problem, but, whenever I use the CD Burning Wizard to burn files straight from the folder, it won't recognize my blank CDs either....wierd...at least I can use Record Now and finally listen to some new music in my car....
ZOMB13 is offline
post #12 of 18 (permalink) Old 12-19-2006, 02:56 PM
EDIT:
WMP 11 is pure cr*p on Vista there is no plugin for other browser to view embedded Windows Media. Nice going Microsoft.
Regards
André
fettouhi is offline
post #13 of 18 (permalink) Old 12-19-2006, 07:45 PM Thread Starter
Regards
André
Ouch...so what should I do then?
ZOMB13 is offline
post #14 of 18 (permalink) Old 12-19-2006, 10:54 PM
When I first got MP11 it was great and shortly after I started realizing that you couldnt do anything without the plugins (which you have to pay for) but listen to music.
When you try something you dont have a plugin for, it should give you a link to their page with all the plugins and you can pay and download them from there.
crevis is offline
post #15 of 18 (permalink) Old 12-19-2006, 11:45 PM Thread Starter
So burning music with WMP 11 is a pay for only setting now?
ZOMB13 is offline
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
Saddle problem on Edge Pro ThomasBJ Tech: Setup, Repairs and Mods 11 04-12-2005 02:05 PM
JCM2000 DSL100 volume swell problem Joshka Gear, Equipment, Recording & Off Topic 40 04-14-2004 05:49 AM
I've finally got the RG2820...however, one problem..advice? triaxis All Other Guitars (including Prestige) 11 11-16-2003 09:06 PM
Input Jack - ... anyone else got this problem? Fabe Tech: Setup, Repairs and Mods 0 03-28-2002 06:29 AM
