PC USB Problem - Jemsite
post #1 of 8 (permalink) Old 10-12-2007, 06:47 AM Thread Starter
PC USB Problem
Guys,
I am having some problems with my PC that I need to sort out to start using it for recording.
Iíve had it about 18 months and have never been able to get the USB ports to operate at USB 2.
I am running XP Pro service pack 2 which I have re-installed to no avail.
The motherboard is an Asus P5S800-VM which I know is USB 2 compatible
I have checked the setting in the Bios is correct (weirdly, when I select USB 2 the ports donít work at all)
I bought a USB 2 PCI card but that wouldnít run at USB 2 either.
I am not sure what else to do, other than buy a new board. I havenít been able to find an answers on the ASUS forum.
Any suggestions welcome,
Thanks
Dazza1004 is offline
post #2 of 8 (permalink) Old 10-12-2007, 07:19 AM
Reviews: 3
Re: PC USB Problem
Have you checked that the wire for the usb port is connected to the usb pins on the motherboard correctly?
Wild_Child is offline
post #3 of 8 (permalink) Old 10-12-2007, 10:38 AM
shredmaster's Avatar
Re: PC USB Problem
flash the motherboard bios to the recent version
shredmaster is offline
post #4 of 8 (permalink) Old 10-12-2007, 10:43 AM Thread Starter
Re: PC USB Problem
I think that is my next stop, seems a bit more involved that the usual stuff I am used to but will give it a go non the less
post #5 of 8 (permalink) Old 10-12-2007, 11:15 AM
Re: PC USB Problem
after that go to device manager, uninstall ALL usb ports. reboot the machine. XP sp2 will see them and reinstall them. if it doesn't work after that i would manually install the drivers from microsoft....do a search for usb 2 drivers. it will update in xp. sometimes xp isn't good enough and you have to manually install some update / patch.
post #6 of 8 (permalink) Old 10-15-2007, 04:20 PM
Re: PC USB Problem
so what happened?
post #7 of 8 (permalink) Old 10-15-2007, 05:06 PM Thread Starter
Re: PC USB Problem
hi mate, you were right, updated the bios and it sorted it out.
Many thanks for the advice
post #8 of 8 (permalink) Old 10-15-2007, 11:22 PM
Re: PC USB Problem
awesome! glad it worked and i'm glad i could help!
Volume pot problem (sustainiac related) AirGuitar Tech: Setup, Repairs and Mods 1 10-01-2007 05:32 PM
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
Saddle problem on Edge Pro ThomasBJ Tech: Setup, Repairs and Mods 11 04-12-2005 02:05 PM
JCM2000 DSL100 volume swell problem Joshka Gear, Equipment, Recording & Off Topic 40 04-14-2004 05:49 AM
I've finally got the RG2820...however, one problem..advice? triaxis All Other Guitars (including Prestige) 11 11-16-2003 09:06 PM
