Printer Problem - Jemsite
post #1 of 3 (permalink) Old 02-02-2008, 10:07 PM Thread Starter
Printer Problem
I have a epson R200, and it has the two blinking read light on them, and everytime i turn it on, theres this snapping noise i hear, and second that snapping noise happens the red lights are blinking, i think i know the source of the problem, but i dont know how to fix it, i have already used SCC Utility if anyone wanted to know, but heres a pic->
Here is my ink holder:
and i think its getting snagged on this.
LethalAe86TypeR is offline
post #2 of 3 (permalink) Old 02-02-2008, 11:39 PM
Reviews: 3
Re: Printer Problem
With my old Epson, the "teeth" on the bottom of the printhead assembly (the thing holding the ink) would get misaligned. Usually happened because the stupid thing would not stop properly when you tried to change the ink.
Anyway, it probably isn't recomended, but manually pushing it to its docking spot to the far right hand side and then closing the lid, power-cycling, would generally fix things.
Attempt at your own risk.
jay ratkowski is offline
post #3 of 3 (permalink) Old 02-03-2008, 02:08 AM
Re: Printer Problem
Yeah, I had an Epson r200 that did the same thing. I put it in ink changing position, and then un-plugged and then worked it back in forth manually a few times. It should move freely. I then closed the lid, plugged it back in and let it cycle. Not really sure why but that worked for me.
As Jay said though, try at your own risk.
Distantshore is offline
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
Saddle problem on Edge Pro ThomasBJ Tech: Setup, Repairs and Mods 11 04-12-2005 02:05 PM
JCM2000 DSL100 volume swell problem Joshka Gear, Equipment, Recording & Off Topic 40 04-14-2004 05:49 AM
guitar man with nothing but bad attitude Joshka All Other Guitars (including Prestige) 0 02-25-2004 09:58 AM
I've finally got the RG2820...however, one problem..advice? triaxis All Other Guitars (including Prestige) 11 11-16-2003 09:06 PM
