Shipping a guitar without a case - Jemsite
post #1 of 8 (permalink) Old 04-16-2013, 08:45 PM Thread Starter
Hey guys,
Im about to ship a guitar but I dont have a hardshell case for it. In the past I've received guitars without hardshell cases and they have been totally fine, but I forget how the one guy that sent me one disassembled did it.
Whats the best way to do it if I disassemble?
Stealthtastic is offline
post #2 of 8 (permalink) Old 04-16-2013, 10:22 PM
Reviews: 11
Re: Shipping a guitar without a case
Its always best to leave it strung under tension, but if you want to split it apart, heres how I would suggest doing it.
Remove strings
LOOSEN THE TRUSS ROD. Put a peice of tape of masking tape over the neck telling the buyer to remember to tighten it back up
Bubble wrap the neck copiously. Box it up tight
For the body Its pretty simple, just wrap it up. I stick rolled up cardboard tubes to create support points on the neck joint, and then rolled up cardboard in each corner and tape them in.
edit: there is more then one way to skin a cat, this is just how I've done it successfully in the past.
linuxpenguin is offline
post #3 of 8 (permalink) Old 04-16-2013, 10:24 PM Thread Starter
Yeah that's what I was thinking of doing as well. Curious though, why bother loosening the truss rod? I left an RG 7421 unbolted with no string tension in my garage for a year once, and the neck was fine after, just needed a bit of an adjustment.
post #4 of 8 (permalink) Old 04-16-2013, 11:15 PM
webmaestro's Avatar
If you send them detached, I wonder if (in addition to other packing and precautions), you could put the neck inside one of those sturdy poster/mailing tubes. I thought of this recently when sending a guitar to be refinished. I was contemplating sending it sans case with the body and neck detached. I have a bunch of these tubes in my office for storing project posters and whatnot, and they're really sturdy--you can practically stand on them without crushing them. I thought they'd be sweet as extra protection for the neck inside the bigger shipping box. I didn't end up doing it though--I sent them attached and in the case instead (at the request of the guy doing the refinishing).
If you can find one of those tubes and it's long enough, it might afford some extra protection/support. Put the neck inside the tube, fill the dead space (inside the tube) with whatever--bubble wrap or paper--then wrap the tube in bubble wrap and put that in the bigger box with the body.
I think the body's pretty easy. Just wrap the hell out of it with the big bubble wrap... so there's a good 6"-8" of bubble wrap on all sides.
webmaestro is offline
post #5 of 8 (permalink) Old 04-16-2013, 11:24 PM
Reviews: 11
Its honestly simply a "better safe then sorry" precaution. Think about it, you get a steel beam inside the neck putting lots of pressure to bend the neck against the strings. When you remove the strings, its simply pushing with no resistance and can actually warp the neck.
post #6 of 8 (permalink) Old 04-16-2013, 11:32 PM Thread Starter
Yeah sounds good! I found a prestige case btw, check your fb messages!
Good call, you are right 110%!
post #7 of 8 (permalink) Old 04-17-2013, 07:36 AM
I shipped this guitar to Australia in pieces with no case.
The buyer didn't want the case and wanted to save on the expensive shipping charge, which is calculated by total box dimensions. I think he saved something like $150.
I took a regular guitar box which is slightly bigger than a standard case and cut it down. I used a ton of bubble wrap on the parts. I made caps out of bubble wrap for both ends of the neck and then re-wrapped the whole thing. Same for both horns on the guitar. Trem was wrapped up in a bubble in there too. Then the key is to have the whole box packed TIGHT with packing peanuts.
I've received a complete guitar that was just really wrapped in bubble wrap and two guitars in gig bags. It's all about using adequate packing. If you shake the box and can hear it moving around inside, that's not enough packing material. That's how damage happens.
Takin' a Ride is offline
post #8 of 8 (permalink) Old 06-09-2013, 09:24 PM
Check with your local guitar store, and see if / how they've done this in the past.
blacksmith73 is offline
hffff
JEM777 BRMR with Case...FREE US SHIPPING RGrocker Classified Ads: Ibanez JEM/UV Guitars 4 05-19-2008 07:43 PM
shipping a guitar? Distantshore Off-topic / Miscellaneous 1 08-18-2007 11:50 PM
WTB: RG7620 inc case and shipping ~ £300/$560 Devo Classified Ads: Guitars and Gear 4 01-16-2007 12:46 PM
Shipping weight of a JS1200 + Case.??? CrazyD Ibanez JEM, UV, JS & Other Signature Models 4 09-23-2005 05:17 PM
Shipping, if theres no case does it get ruined? carlos grijalva Gear, Equipment, Recording & Off Topic 4 06-16-2005 01:49 AM
