*HELP*- How can i get low action? - Jemsite
post #1 of 5 (permalink) Old 09-18-2001, 09:42 PM Thread Starter
I have a 7dbk and i would like to get lower action for finger tapping. What do i tweek on my guitar to get low action? And how can i get the strings closer to the frets for a crisper tone when finger tapping? *
im studying Stanley Jordan, AND I NEED LOW ACTION!!!!!!!!
vaidream77 is offline
post #2 of 5 (permalink) Old 09-18-2001, 10:09 PM
rvj
Did you try lowering the trem?
rvj is offline
post #3 of 5 (permalink) Old 09-19-2001, 12:23 PM
lowering the trem/getting the spring tension right/playing around with the trussrod...
If you know how to do it fine, if not either get a guitar tech to do it for you (only needs to be done once unless you plan to change string gauges). Or alternately get a good book on guitar setups and practice on a guitar that can get a bit hurt and when confident set up your 7dbk.
Have a look at some of the faq areas of jemsite, they should tell you a lot about what you need to know and how to do it.
James
7 Dying Trees is offline
post #4 of 5 (permalink) Old 09-19-2001, 12:29 PM
site founder 0% owner
jemsite's Avatar
click GUITARS from the green menu then TECH/SETUP and start reading ...glen
jemsite is offline
post #5 of 5 (permalink) Old 09-20-2001, 10:52 PM
On a similar tangent -- my action HAS been altered despite using the same guage strings. *When replacing old D'Addario's with Gibsons, by tremolo angle went up a little bit, and correspondingly the action. *I'm going to readjust the trem back to parallel, but yikes, im still using 9's and my bridge is action weird!
warmregards is offline
guage strings , guitar tech , stanley jordan , string gauges , tremolo angle
12th fret action vs. 24th action abstract_noise Tech: Setup, Repairs and Mods 12 04-19-2014 12:34 PM
Action! SilverEra Polls 12 12-11-2009 10:38 PM
How do you like yer action? Severinsteelsmith Tech: Setup, Repairs and Mods 15 09-10-2009 06:23 PM
new rga's in action evil_k666 All Other Guitars (including Prestige) 27 07-29-2005 02:22 PM
Still Need Lower Action - My action is like 3 mm, can you he nickjm Tech: Setup, Repairs and Mods 16 06-04-2001 01:50 AM
HTML code is On
