1st string problem - Jemsite
post #1 of 9 (permalink) Old 06-29-2010, 02:27 PM Thread Starter
1st string problem
I have a Joe Satriani model. The 1st string breaks up when played, its almost a vibrato type thing. More pronounced when using distortion. The other strings ring clear. Anyone else had this problem?
sixstring is offline
post #2 of 9 (permalink) Old 06-29-2010, 03:52 PM
Re: 1st string problem
does it break up when you play it open or when fretted?
most likely its hitting against a fret. If its open then your nut will need to be raised, if its while you fret then you might consider adding a shim underneath the first string saddle. or you could raise the bridge on the side that your having the problem. Also check neck relief that will effect all strings.
eruji is offline
post #3 of 9 (permalink) Old 06-29-2010, 07:04 PM
How do you raise a floyd nut?
newbieguitarmaker is offline
post #4 of 9 (permalink) Old 06-29-2010, 07:06 PM
You can shim it up, but for just one string you can put a small dab of crazy glue in the V of the locking nut to raise it a bit.
eruji is offline
post #5 of 9 (permalink) Old 06-29-2010, 08:36 PM
jb4674's Avatar
Reviews: 18
Where does the string break from? Is it at the saddle? If that's the case, you need to file the groove of the saddle and make sure there's no sharp areas where the string can get caught thus making it break.
Jimmy
jb4674 is offline
post #6 of 9 (permalink) Old 06-30-2010, 04:16 AM
Steady on, before you go filing anything, what do you mean by 'break up'? Buzz?
chris101 is offline
post #7 of 9 (permalink) Old 06-30-2010, 10:45 AM
i think he is referring to the sound breaking up not the string actually breaking, but i could be wrong.
eruji is offline
post #8 of 9 (permalink) Old 06-30-2010, 10:27 PM
Reviews: 15
It sounds to me that the right side of the bridge is too low, or a fret is high. It's a classic case of buzzing.
Also make sure that the neck isn't warped (slightly twisted). Look down the length of the neck from the headstock down.
lespauled is offline
post #9 of 9 (permalink) Old 07-01-2010, 12:46 PM
Try loosening your truss rod. When a truss rod is tightened beyond necessary, it starts affecting the side of the fretboard where the high strings are first.
Now the edit part:
What I've written above goes for one or two frets choking the note.
If the vibrato sound happens when you play an open string only, you have to replace the locking nut. It used to happen to me when I had a Fender Stratocaster. My B string would sound strange when played open, with a slight vibration sound like you described.
Does it sound floppy as soon as you pick it, like when you're tuning a string after replacing it, and it's still very flat to produce a decent sound?
Melek Taus is offline
joe satriani model
Des Anyone Else Have This String-Changing Problem????? jemaholic Ibanez JEM, UV, JS & Other Signature Models 48 12-18-2006 12:31 AM
G string problem, please help ! Professor Jones Tech: Setup, Repairs and Mods 9 01-22-2006 12:35 PM
Jem7vwh g string problem unique77 Ibanez JEM, UV, JS & Other Signature Models 16 03-24-2005 11:07 AM
String Problem! Help! The Wood Tech: Setup, Repairs and Mods 6 07-15-2004 10:00 AM
7th String Sustain Problem The_Grindfiend All Other Guitars (including Prestige) 5 02-12-2004 12:06 PM
HTML code is On
