2 Questions - high pass pot & body - Jemsite
post #1 of 4 (permalink) Old 01-03-2001, 11:36 PM Thread Starter
ok...I want to build a guitar. With a JS body and everything else I'll put custom and stuff....with a swirl paintjob. Now, I found a guy who would make a copy of a JS body for me.....for 550....now should I buy the body? Or buy the complete JS and rip it apart and build it back up? Also, I'd like a high pass filter and the single coil tap, now if I put a seperate volume knob for each pickup (les paul style) does the high pass filter only work on the pickup the volume/high pass filter is asigned to? Thanx for your help.
Ryan
RSVampire is offline
post #2 of 4 (permalink) Old 01-03-2001, 11:41 PM
2 Questions
When you can get the full deal for not that much more I'd buy the whole guitar, the parts you don't use, I'll buy from ya As for the techy stuff, boy was that Degree in Electronics wasted on me!! :biggrin:
Rich is offline
post #3 of 4 (permalink) Old 01-04-2001, 01:11 AM
2 Questions
If this guy builds the body, from where do you plan to get a neck? If the JS neck is not a huge problem for you I would *get the whole guitar and then modify it.
Good luck!
alienx is offline
post #4 of 4 (permalink) Old 01-04-2001, 09:45 AM
2 Questions
The high pass filter is simply a capacitor, I believe. Jems have this too, only it's not switchable. I never really saw the point of having it switch, but that's just me. If you want it switchable, you could do it with only one knob, if you bought the right pot (). However, if you want a volume control for each pickup, it may be easier to use a micro switch instead. Same goes for tap.
iain is offline
coil tap , high pass filter , les paul
High pass filter pot - where to buy? mag8 Tech: Setup, Repairs and Mods 0 12-06-2011 04:10 AM
High Pass Filter guitar425 Pickups & wiring 5 05-30-2007 08:33 AM
High pass capacitor? Drew Tech: Setup, Repairs and Mods 3 02-06-2005 12:01 PM
High Pass Filter ZeroDrift Ibanez JEM, UV, JS & Other Signature Models 3 01-27-2005 03:18 AM
Where can i get a high pass filter Blackstrat86 Ibanez JEM, UV, JS & Other Signature Models 17 03-16-2003 11:16 PM
HTML code is On
