7 string neck help please. - Jemsite
post #1 of 8 (permalink) Old 01-28-2008, 05:15 AM Thread Starter
Hi, i have a rg7620, ive played unis and other 7s but for the life of me I cant remember if the neck profiles differ? my 7620 as i imagine all 7620 have a thick neck behind the B and then taper out as the neck moves down toward the E is this the same on all other ibanez 7 necks? the uni has a conventional convex shape with the thickest point being behind the center of the neck doesn't it or am i going/gone frazy? cheers for your help.
HAGO
Alan
Out Of This Swirled is offline
post #2 of 8 (permalink) Old 01-28-2008, 08:04 AM
Re: 7 string neck help please.
The UV profile has changed a fair bit over the years. my UV7PWH is a fairly thin affair with a flat-ish profile while my UV777PBK is much more rounded and thicker.
Algiman is offline
post #3 of 8 (permalink) Old 01-28-2008, 08:15 AM Thread Starter
hi cheers for responding, are your git necks all symmetrical or is the neck below the B thicker on that side than the E side?
post #4 of 8 (permalink) Old 01-28-2008, 08:34 AM
I've only got the 7PWH to hand. If anything the profile tapers a little more on the low b side - in other words it is a bit thicker towards the high e. Weird. Never really thought about that before.
Algiman is offline
post #5 of 8 (permalink) Old 01-28-2008, 09:07 AM Thread Starter
weird? mine is well thick on the B side like holding a 2x4! its not really that bad. anyone else out there with a rg7620 that can help me out? im pretty sure the uni i played was just like a 6 only wider. cheers again mate.
post #6 of 8 (permalink) Old 01-28-2008, 10:24 AM
Reviews: 5
I have owned like 3 7620s and have never noticed this tapering. Mine were all slim and even across the back. Maybe the previous owner sanded it down?
djpharoah is offline
post #7 of 8 (permalink) Old 01-28-2008, 10:24 AM
My RG7620's neck has always seemed fairly uniform and flat to me, but I guess I've never really paid that much attention to it. I'll have to look at it when I get home.
djohns74 is offline
post #8 of 8 (permalink) Old 01-28-2008, 11:51 AM
Again, depends on the year. The newer UV's like mine are thicker than the older necks, and the profile isn't uniform, it's D shaped. Tough to explain, but as mentioned, you should really try them out for yourself because they vary substantially between models and even different years of the same models.
heffergm is offline
FS: Lefty 7 LGM string neck fettouhi Classified Ads: Guitars and Gear 13 07-31-2007 04:07 AM
Anyone know who could make me a 7 string body and neck like this? sah5150 All Other Guitars (including Prestige) 21 04-06-2006 04:04 PM
for trade , ibanez usrg30 j.arledge Classified Ads: Guitars and Gear 2 03-07-2006 09:14 PM
Very loose neck to neck pocket fit, what do I do? SilverSurfer2 Tech: Setup, Repairs and Mods 3 07-29-2005 09:00 PM
cutting an original neck to become an all access neck Zeroleet Tech: Setup, Repairs and Mods 32 05-05-2005 09:08 AM
HTML code is On
