7dbk Question - Jemsite
post #1 of 20 (permalink) Old 04-29-2004, 12:53 PM Thread Starter
7dbk Question
is it normal for the tone pot to be bypassed? im fairly sure it didnt work straight out of the store, i jst had to have it though. also if i remember correctly it has a 250K tone pot, which suprised me. ive looked at the wiring and am somewhat lost
any help would definately be appreciated
prefontainenike is offline
post #2 of 20 (permalink) Old 04-29-2004, 12:54 PM
Was this new or used?
Rich is offline
post #3 of 20 (permalink) Old 04-29-2004, 01:34 PM Thread Starter
new from guitar center bought in 2001
post #4 of 20 (permalink) Old 04-29-2004, 01:38 PM
If you can tell the pot is a 250k then evidently you've pulled the guard and discovered the wiring bypassed too? Remember this is GC where you can return a guitar umpteen days later for full refund, after you've tweaked it around any number of ways, and nobody checks upon it's return. The pot should be 500k and not bypassed of course.
Rich is offline
post #5 of 20 (permalink) Old 04-29-2004, 01:46 PM Thread Starter
ive looked around the inside but i have no idea as far as wiring goes. ill open it up and take some pics, at first i didnt care, but now that ive gotten better i NEED my tone pot. the 250k doesnt bother me to much as i play way more lead than anythng and almost solely on the single
btw what does a bypassed tone pot look like? as far as if it is or not im not sure, a friend said it was, but like he knows, it could just be busted or miswired, who knows
post #6 of 20 (permalink) Old 04-29-2004, 02:53 PM Thread Starter
ok here are some pics
as far as the wiring goes there are two black wires connected to the back of the tone pot, 1 im guessing is the ground as it is wired onto the metal that spring thing in the back. the other black wire goes directly onto the back of the volume pot (pics 2,3), awhite wire connects the left metal tab to the left tab on the volume pot (3), the other 2 tabs on the tone pot are bent and touching each other (1), the right tab on the volume pot is bent and soldered onto the volume pot (3), it also appears as if there was a wire that was connected to the middle tab on the tone pot(1)
post #7 of 20 (permalink) Old 04-29-2004, 03:27 PM
Here's the diagram
http://www.ibanez.com/wiring/wire.asp?y=2001&w=JEM7
BTW, all you had to do was pull the pickguard with everything attached, it'll come off plenty far to do anything behind it
Rich is offline
post #8 of 20 (permalink) Old 04-29-2004, 03:45 PM Thread Starter
hahah yeah but i just put new strings on yesterday, so i didnt want to rip them off, ill check the link out, just as i thogh, the tone pot is missing a wire from the middle tab to the volume pot, is wire all of the sme quality and or type?
post #9 of 20 (permalink) Old 04-29-2004, 03:48 PM
Rich is offline
post #10 of 20 (permalink) Old 04-29-2004, 03:54 PM Thread Starter
god damn! thats helpfull, now, whats the easiest way to get the the pickeup springs attached correctly
post #11 of 20 (permalink) Old 04-29-2004, 03:58 PM
Not take them off to begin with
Pull the trem so you have room to work.
Rich is offline
post #12 of 20 (permalink) Old 04-29-2004, 04:18 PM Thread Starter
unreal site, i have so much stuff to do to fix this up, as far as wires go are they all the same? i want to see what this guitar REALLY sounds like
post #13 of 20 (permalink) Old 04-29-2004, 04:21 PM
Just stick to the same gauge and you'll be fine
Rich is offline
post #14 of 20 (permalink) Old 04-29-2004, 04:30 PM Thread Starter
i have no idea what gauge the wire is, how do i find out?
post #15 of 20 (permalink) Old 04-29-2004, 05:59 PM Thread Starter
it works it works finally
now to see whether or not i like it working
somebody had all the wires changed from the iring diagram, damn them
.... i spoke to soon, as soon as i gt it all sealed up, the humbucker seems to be like 1/4 the volume, uh oh, hopefully its just a loose wire
Fs: Jem 7dbk ShredderJoshW Classified Ads: Ibanez JEM/UV Guitars 9 06-07-2006 04:32 AM
looking for a jem 7dbk arkame Classified Ads: Ibanez JEM/UV Guitars 4 06-05-2006 05:50 PM
7DBK at 1.2K xklusivly4u Ibanez JEM, UV, JS & Other Signature Models 11 11-26-2005 09:56 AM
JEM 7DBK case question Eguess Ibanez JEM, UV, JS & Other Signature Models 3 06-10-2003 12:04 PM
HTML code is On
