7VWH tremolo low-pro-edge only raises no more than a halftone!!! Help please. - Jemsite
post #1 of 5 (permalink) Old 09-18-2011, 07:29 AM Thread Starter
Hi...
i need your help.
Because my Ibanez JEM 7vwh doesn't come back in full pitch after a pull-up of the tremolo (Lo-Pro Edge), i read about the Chapman Stick and bought one.
Then I tried to take off the tremolo as described on the ibanezrules-site.
As i watched that tremolo, i saw that one knife-edge (the right) has got a half circle filed into it. Nevertheless it worked before so that should not be the problem.
To correct the action height, i drew the posts a little bit more in to the guitar and put the tremolo back into the guitar. Now the string height was a little to deep, so tone was killed when doing some bending. So i went through all this again and raised the posts a little bit. Now it's better.
As I put in the tremolo again and tried to play a little bit, I notices, that I could only raise the tremolo no more that a halftone.
My RG 4020 does it better, without a lion claw..
I think, the bottom plate (with the knifeedges) of the tremolo touches the wood, where the posts are screwed into.
Are the posts drilled to deep into the wood? Even if action is ok?
What can i do about that?
Fit the inner neck screws with something to give the neck another angle and raise the posts?
Please help.
Thank you...
Mallone..
Mallone is offline
post #2 of 5 (permalink) Old 09-18-2011, 12:39 PM
Reviews: 4
Re: 7VWH tremolo low-pro-edge only raises no more than a halftone!!! Help please.
U will have to shim the neck. Unscrew the neck, stuck a small piece of business card and attached the neck back again. After that, readjust the action and play. If it isn't enough, just fold the business card and add on till your preferred height.
http://www.ibanezrules.com/tech/grunge/grunge_6.htm
Here is a link on how to do it.
faekildare is offline
post #3 of 5 (permalink) Old 09-18-2011, 05:56 PM
RGTFanatic's Avatar
You have the bridge far too low in the body. Follow Faekildare's advise on shimming the neck, but you'll also have to raise the bridge away from the body
RGTFanatic is offline
post #4 of 5 (permalink) Old 09-19-2011, 08:39 AM Thread Starter
Thank you.. shimmed the neck and it's much better now..
One small additional question:
When playing distorted i notice a massive impact of noise from every little touch on the body.
This seem to reduce when screwing the pickups lower...
Is this the cost of the high output evolution pickups?
Mallone is offline
post #5 of 5 (permalink) Old 09-19-2011, 08:53 AM
Reviews: 4
Touch meaning knocking on it or just light touching it? If it's light touching the strings, then yes, but if you are constantly muting it, then it's ok.
7vwh , jem , lo-pro-edge , whammy
Is the Edge-Zero II Tremolo a good tremolo system dburn42 All Other Guitars (including Prestige) 6 05-30-2011 10:12 AM
Can I replace Jackson JT580 with Edge Pro or Edge III Tremolo? Izzyprad Tech: Setup, Repairs and Mods 11 05-04-2010 08:57 AM
1993 7VWH with Edge Pro Tremolo (versus 2006) atlantajem Ibanez JEM, UV, JS & Other Signature Models 24 02-08-2010 07:24 PM
Ibanez EDGE PRO tremolo, GOLD for Jem 7VWH and others, near new atlantajem Classified Ads: Guitars and Gear 1 02-08-2010 03:15 PM
WTB: Edge Pro Tremolo or Trade for mint Original Edge For_The_Love_Of_Jems Classified Ads: Guitars and Gear 3 02-12-2008 01:24 AM
HTML code is On
