To Case or not to Case - Jemsite
post #1 of 21 (permalink) Old 09-07-2014, 08:35 PM Thread Starter
Hello friends, I'm sure this topic has been covered before but I can't find anything that directly answers my question. What I'm wondering is this: I found a Hercules brand guitar stand/rack that holds 5 guitars and I've been thinking this would be a wonderful way to display some of my favorite guitars, not to mention how nice it would be to just easily grab any guitar I want right from the rack without having to go through the cases. My only concern, is if I keep my guitars on this stand that means they aren't in their cases most of the time (now I have them in their cases always). I have read that humidity and temperature don't have much effect on electric guitars, they are pretty solid and don't easily warp. However, these are my babies! So I wanted to run this by you guys to get some opinions first. I thought I could throw a sheet over it at night to prevent any kind of dust, and I don't see them getting knocked over as an issue. So the only reason NOT to do the rack idea is if the humidity and temp changes through the seasons are an issue. The room has a pretty constant temperature of about 76 degrees, however living in Tucson it can get very very dry. I don't have any kind of humidifier for the room, but again, I've read with electric guitars this isn't much of an issue? What do you all think? Thanks for your advice!
scalelokt is offline
post #2 of 21 (permalink) Old 09-07-2014, 09:42 PM
Re: To Case or not to Case
I have all my guitars hanging from the walls or on stands and I don't have any problems.
If you keep your house close to a temperature constant, there is really no need to worry about anything. If you have mad swings in temperature and humidity, it may be a different story.
POS RG is offline
post #3 of 21 (permalink) Old 09-07-2014, 10:38 PM
It would be advisable for you to get a humidifier, without the proper humidity levels electric guitar neck woods can shrink and expose your fret ends.
Fastmerc is offline
post #4 of 21 (permalink) Old 09-08-2014, 09:32 AM
I wouldn't think a room humidifier necessary at all for electrics. I've kept mine out of my cases for years (only put then in when transporting between gigs), and absolutely nothing has changed on them. The most you'll have to do is wipe down dust on occasion.
Now, when I had two high-end classicals I had to keep a humidifier in both the room and the case, but those were super sensitive to any changes, having french polish finishes and all that exposed wood on the inside.
I've never known a luthier to be concerned about humidity affecting fretboards on any guitar, as long as they're oiled on occasion.
Archlute is offline
post #5 of 21 (permalink) Old 09-08-2014, 09:36 AM
elcid's Avatar
Yep
First winter in my new house this happened. had to have the frets worked on on 8 of my electrics. Even worse this last winter it was so dry the top of my Orville LP cracked in 4 places, and that was with a whole house humidifier.
elcid is offline
post #6 of 21 (permalink) Old 09-08-2014, 10:44 AM Thread Starter
Thanks everyone for the responses! It looks like there are a variety of opinions here, ranging from electrics being out of their cases for years with no issues, to electrics having neck issues after one dry winter. This is pretty representative of all the internet searches I did, it seems to be a real grey area as to whether you can leave electrics sitting out or not. One question I have (and it might be a stupid question) is if you are in a very dry house during the winter for example, wouldn't the air in your guitar case be just as dry as the air outside it? In other words from a humidity perspective why does the case even matter?
post #7 of 21 (permalink) Old 09-08-2014, 01:27 PM
I leave mine out. They're easier to play that way, and for me that;s the whole point of having them. I use a soundhole humidifier on my acoustic, but that's it.
Drew is offline
post #8 of 21 (permalink) Old 09-08-2014, 01:36 PM
I leave mine out also, but Im in Florida where it it is always very humid. Any type of closed container promotes humidity even in dryer climates, does that mean your case will keep anything from happening vs being stored out of the case I couldn't tell you.
Fastmerc is offline
post #9 of 21 (permalink) Old 09-08-2014, 02:38 PM
elcid's Avatar
I still don't case mine, according to my tech this last winter was especially brutal around here and he had a ton of issues with guitars drying out. This winter I might add an additional in room humidifier and maybe use some oil on the top of my LP
elcid is offline
post #10 of 21 (permalink) Old 09-08-2014, 07:09 PM
We had a brutal winter up here! I kept all of mine out on the wall hangers. I have a very good whole house humidifier and it doesn't drop below 40%. I'll probably put in a small unit in the basement studio just for some extra insurance. Either way, I had no issues other than the necks slightly moving a very little bit which normally will happen with changing seasons, anyways. I run a dehumidifier during the summer months to keep things even as well.
PBGas is offline
post #11 of 21 (permalink) Old 09-09-2014, 12:01 PM Thread Starter
You know the more I think about it the more it seems like leaving electric guitars out isn't a problem, so long as the room doesn't have drastic temp and humidity changes. If you think about it, every guitar store in the world leaves their guitars out 24/7 on wall hangers and stands. If it ruined them they would be in serious trouble no?
post #12 of 21 (permalink) Old 09-09-2014, 12:27 PM
That is a problem at alot of stores, not that it ruins them but that they are awful to play off the wall.
Fastmerc is offline
post #13 of 21 (permalink) Old 09-09-2014, 02:11 PM
The problem you're going to have in Tucson is low humidity. It may be difficult to maintain proper humidity in a large room there. It would be easier to maintain humidity in a case with a case humidifier.
Takin' a Ride is offline
post #14 of 21 (permalink) Old 09-09-2014, 02:53 PM
I leave mine racked for the summer and in their cases over the winter period - October through to March.
Arkks is offline
post #15 of 21 (permalink) Old 09-09-2014, 03:57 PM
I keep mine in cases, they're safer that way. Not to mention UV light exposure as all my guitars are neons.
Gojira is offline
guitar case , humidity , warping , wood
Hard Case Latches broken from case (PICS) ErickMoral Tech: Setup, Repairs and Mods 9 07-10-2013 06:48 AM
2008 Caparison TAT II in Red Sunset w/case, bar & case candy - Near Mint Sevenstringer Classified Ads: Guitars and Gear 1 05-04-2013 11:40 PM
Ameritage Electric Guitar Case and Taylor Luggage Dreadnaught Case Sevenstringer Classified Ads: Guitars and Gear 3 12-20-2012 10:23 PM
Hard-Case. Ibanez EDA1000C Bass Case - NEW $40 Bowie Classified Ads: Guitars and Gear 0 10-12-2008 01:08 AM
Want to Buy - Tounge latch for UV1000 HARD SHELL CASE, SAME CASE THE JEM SHIPS IN cradleofphil Classified Ads: Guitars and Gear 9 01-28-2007 01:29 PM
HTML code is On
