Center distance of 7str UV tuners? - Jemsite
post #1 of 4 (permalink) Old 02-20-2008, 05:42 AM Thread Starter
Question Center distance of 7str UV tuners?
Anyone knows what the Centre to centre distances of the Tuners on the 7-String UV are?
25mm ?
Metallion is offline
post #2 of 4 (permalink) Old 02-20-2008, 03:47 PM
Re: Center distance of 7str UV tuners?
Do you mean the distance along the line the tuners are in? I could take a measurement if you want. However if you are going to use it to make a headstock you would have to be very careful to get the angle of the line just right. In that case it might be better to draw lines where the strings are going to be (perfectly parallel of course), then draw a line along the upper edge of the headstock, and put the tuners at the points where the lines intersect.
Cheers
urdvurk is offline
post #3 of 4 (permalink) Old 02-20-2008, 03:58 PM
By the way, I make that about 24 mm, give or take a few tenths depending on where I measure.
And I was wrong: the tuners should not be at the intersection points but up a little so the strings go straight from the nut to the circumference of the tuner.
urdvurk is offline
post #4 of 4 (permalink) Old 02-28-2008, 07:36 AM Thread Starter
To get the Strings right: What is the distance from the high to low string at nut?
UV7 vs RG7620 Jem666Sk All Other Guitars (including Prestige) 52 07-05-2009 08:35 PM
trans siberian orchestra shredmaster Off-topic / Miscellaneous 5 11-10-2005 12:57 PM
WTT: Cosmo tuners for chrome tuners Jeff Classified Ads: Guitars and Gear 0 06-28-2005 10:55 AM
Direct retrofit Locking Tuners for RG7621 Drache713 Gear, Equipment, Recording & Off Topic 2 12-05-2002 10:03 AM
UV777BK or RG2027x or 7VWH - need help deciding my first... 6stringsorcerer Ibanez JEM, UV, JS & Other Signature Models 16 09-02-2001 11:32 PM
HTML code is On
