Coil tap the bridge humbucker? Possible? - Jemsite
post #1 of 6 (permalink) Old 11-23-2008, 08:42 PM Thread Starter
Is it possible to install a coil tap on the bridge humbucker to get a single coil sound out of a Jem.
Forgive the question, I'm mainly a Fender guy, and the only guitar I own that has humbuckers is a Silvertone hollow body from the late 50s.
What do you guys think?
Blacksunshine is offline
post #2 of 6 (permalink) Old 11-23-2008, 08:46 PM
MFB
Re: Coil tap the bridge humbucker? Possible?
While I want to say it's 100% possible, I don't wanna get caught with my foot in my mouth (or whatever saying you prefer) so I'll so it's 99% very possible
I'm sure people on here have done it, I'll be shocked if no one has
MFB is offline
post #3 of 6 (permalink) Old 11-23-2008, 11:10 PM
You can coil tap any 4 conductor wire humbucker. What were you thinking about using? A push/pull volume or tone pot a dpdt mini switch what?
northlander30 is offline
post #4 of 6 (permalink) Old 11-23-2008, 11:30 PM Thread Starter
Probably a push/pull, so I don't have to cut any holes.
Actually, this was just a thought, I may or may not do it when/if I find a Jem. It seemed like something interesting to do, although I guess I should find a guitar first. I'm not having much luck.
post #5 of 6 (permalink) Old 11-24-2008, 09:09 AM
Entirely possible. I'd use a push push pot as the knobs on most jems are stratlike and come of with pulling the putton up all the time.
But yes, it's very easy to do. With a bit of thinking you can wire it so that you can split both humbuckers, and phase reverse the neck. You can do loads as long as the wirting is kept neat as front mount electrics can be a bit of a bitch to fit if there's too much stuff in there!
But yeah, what you're wanting to do is fairly easy
7 Dying Trees is offline
post #6 of 6 (permalink) Old 11-24-2008, 10:17 AM Thread Starter
Thanks!
WTB: Single Coil 6'r Neck Humbucker djpharoah Classified Ads: Guitars and Gear 1 10-22-2008 01:15 PM
Single-coil-sized humbucker Shredder87 Pickups & wiring 3 07-28-2008 02:11 AM
Help choosing a Bridge humbucker/Neck single-coil combination syan Pickups & wiring 0 11-29-2006 10:42 PM
Single coil sized humbucker? Dee Pickups & wiring 6 05-29-2006 12:16 PM
Exposed Coil Humbucker's - How would this sound on my FP? Andy J Dampier Tech: Setup, Repairs and Mods 3 12-18-2000 04:04 PM
HTML code is On
