Coil Tap doubt - Jemsite
post #1 of 4 (permalink) Old 05-04-2004, 06:27 AM Thread Starter
Coil Tap doubt
I own an JS1000, here is the deal: my coil tap function in the volume doesnt make any difference in my sound, but in the tone coil tap, it do make a difference. Is this ok? should only the tone work?
YisCo! is offline
post #2 of 4 (permalink) Old 05-04-2004, 06:43 AM
I don't own a JS but I thought the push-pull on the volume pot was a high pass filter and that the coil split on the tone works for both pickups simultaneously. Experiment by turning the guitar's volume down half-way, then pulling the knob. There should be more high end in one position than in the other.
Petie is offline
post #3 of 4 (permalink) Old 05-04-2004, 05:56 PM
the tonepoti tap is responsible for the humbucker splitting.
the volumepoti tap activates the high pass filter which you only notice with the volume knob taken back a good bit. doesn't make all that much difference to me, tbh... i kindof ignore it
saTa is offline
post #4 of 4 (permalink) Old 05-07-2004, 04:31 AM
they are correct, the tone knob is the coil tapping feature, the volume knob has the high pass filter which allows the highs to still be present as you roll the volume down (it usually warms up the guitar a bit when you normall roll down the volume)
RSVampire is offline
coil split , coil tap , coil tapping , high pass filter
I have no doubt this is from a... 6fingers Off-topic / Miscellaneous 4 02-12-2011 08:33 AM
Doubt about Blaze wiring caco Pickups & wiring 1 10-11-2010 08:51 PM
Doubt with my Ibanez RG470TI MIJ vicente_romma All Other Guitars (including Prestige) 11 08-02-2008 02:11 AM
I doubt anyone remembers me... JayRobIBZ Off-topic / Miscellaneous 27 10-24-2007 08:49 PM
Please Help! Paypal doubt... zEr0 Vendors, Auction & Reseller Talk 11 10-19-2005 11:55 AM
HTML code is On
