Coil tapping the evo's on my 7vwh - can it be done? - Jemsite
post #1 of 2 (permalink) Old 03-18-2002, 09:34 PM Thread Starter
I'd like single coil sounds on the bridge and neck p/u's. *Can I coil tap my neck and bridge evo's, so that I can have the humbucker sounds as well?
Is this easily done, and reversible? *Can i do it myself, or will a tech be needed? *Also, can i do it to replace positions 2 and 4 on the switching, or must i use push pull pots to reaplace the vol or tone knobs?
thanks.
darthpolster is offline
post #2 of 2 (permalink) Old 03-18-2002, 11:17 PM
site founder 0% owner
jemsite's Avatar
easily done... wiring diagram here in the TECH area:
http://www.jemsite.com/tech/img/t_wd_7ct1.gif
jemsite is offline
coil tap , humbucker sound , wiring diagram
Coil tapping a 7620 EvoGiant All Other Guitars (including Prestige) 4 04-14-2009 11:10 PM
has the RGT 42 coil tapping? schmintan All Other Guitars (including Prestige) 5 01-27-2009 10:10 AM
Has anyone tried coil-tapping an Evo 2? shreddersymphony Pickups & wiring 7 03-11-2008 03:49 PM
Coil Tapping Jem Humbuckers TremoJem Ibanez JEM, UV, JS & Other Signature Models 6 01-11-2007 11:56 AM
Coil Tapping Jem Humbuckers TremoJem Pickups & wiring 0 01-10-2007 06:54 AM
HTML code is On
