Coil Tapping Jem Humbuckers - Jemsite
post #1 of 7 (permalink) Old 01-10-2007, 07:00 AM Thread Starter
Has anyone done this. I need a drawing/schematic which represents the pots, pups and switch with wire color etc. so that I can have a single coil option in the bridge and neck humbuckers by selecting another switch or a push/pull pot. It will allow more flexibility and control over tone. I believe that the Jem would have a killer sound with a single coil in either the bridge or neck position, and this mod would give you the best of both worlds, maybe.
TremoJem is offline
post #2 of 7 (permalink) Old 01-10-2007, 07:24 AM
Re: Coil Tapping Jem Humbuckers
Get a binary switch and connect the black and white wires to one terminal and an earth from a pot to the other, when the switch is on, it will turn off the outside coil. Do the same with the other one. You could do it with one 3 way instead also.
crevis is offline
post #3 of 7 (permalink) Old 01-11-2007, 07:03 AM Thread Starter
I am electiterate, meaning that I can't follow you, sorry, thanks for your effort, but I looked at the wiring diagrams at Ibanez's site and couldn't I use JSs push/pull pot. If so that is the way to go becuase then I don't have to make holes in the pick guard. So how exaclty would a electochallenged guy like me do this exactly. Thanks so much for your help and I understand if you have given up on me.
TremoJem is offline
post #4 of 7 (permalink) Old 01-11-2007, 09:31 AM
Oh yeah, that would be the way to go since its jem, I have lots of switches on my RGs because it just adds character. Just take it to a tech if you're not confident with it and they should be able to get a push pull in as well.
crevis is offline
post #5 of 7 (permalink) Old 01-11-2007, 11:06 AM
Look at the wiring diagram for a JEM, the humbuckers are already split or tapped from the factory...... you could modify the original wiring to eliminate the center pickup from being "on" when the neck or bridge pups are in single coil use. But I think the center pup was included to help eliminate hum or buzz too.
Did you take the time to do a search or review the information from the Ibanez web site????
Here look at this.......
http://www.ibanez.com/wiring/diagrams/2005/JEM7.pdf
jemplayer55 is offline
post #6 of 7 (permalink) Old 01-11-2007, 11:41 AM Thread Starter
yes i have all of this information and wish to add a push/pull pot (same as used on the JS series) to isolate the coil in both position 1 & 5 as a 66th and 7th option, sort of like having a suedo strat but hopefully with better sound.
TremoJem is offline
post #7 of 7 (permalink) Old 01-11-2007, 11:56 AM
I can see how you would do it but the diagram of the push pull isnt detailed enough to work out how the terminals are connected so I couldnt tell you what would go where, it would be an easy mod for any decent tech tho.
crevis is offline
bridge pup , neck humbucker , neck position , wiring diagram
schematic for 5 way switch in JEM / please post iadonism Pickups & wiring 16 12-13-2006 06:16 AM
WTB: Jem Single Coil Act of God Classified Ads: Ibanez JEM/UV Guitars 2 08-09-2006 08:56 AM
Single Coil Sized Humbuckers wallopwallop Pickups & wiring 4 08-20-2002 04:43 PM
Jem single coil height Vai the god of Sound Ibanez JEM, UV, JS & Other Signature Models 7 07-29-2002 07:55 PM
JSifying a Jem - Would you split the humbuckers? crossjem Ibanez JEM, UV, JS & Other Signature Models 4 03-03-2002 11:51 PM
HTML code is On
