DBK Neck Cleaning Solution ? - Jemsite
post #1 of 25 (permalink) Old 08-28-2003, 08:42 AM Thread Starter
What is the best Solution to cleaning a jem neck ?
At the mo I use any old house hold polish.
Should I use any form of oil on the neck ?, what type should I use. I remember hearing that bees wax polish is good!
Gixxer is offline
post #2 of 25 (permalink) Old 08-28-2003, 11:17 AM
Lemon oil is easy to find and cheap. Works fine.
Bore oil is even better, and is used in brass instruments for lubrication. You can find it in any music shop that has more than the obligatory guitar and drums for sale
-Ben
BeastofLove is offline
post #3 of 25 (permalink) Old 08-28-2003, 12:06 PM
Someone once turned me on to the Gibson Fretboard Conditioner. I'm not sure what's in it but judging by the color and smell-there's a good portion of lemon oil anyway. It's good stuff.
Mike 777 Haug
mike777 is offline
post #4 of 25 (permalink) Old 08-28-2003, 12:12 PM
None of the above should be used to CLEAN a neck, conditioning is not cleaning! Try a cloth and some elbow grease
[bore oil is for the bores in woodwind instruments, it's made for *raw* wood which is why it's perfect for fretboards]
Rich is offline
post #5 of 25 (permalink) Old 08-28-2003, 01:16 PM
Reviews: 3
spit n polish does the trick just dont use the same cloth as your body cleaning cloth, heh heh heh, but id say anything advised by the setup master (mr rich harris) is what i'd do
vai n maiden is offline
post #6 of 25 (permalink) Old 08-28-2003, 03:17 PM
Hey Rich- I'll use 0000 Steel wool on the rosewood (and frets) to get rid of any major gunk or tarnishing, and then lemon oil to do a final clean & conditioning; that's ok, right? Elbow grease + the oil appears to clean pretty well... as well as condition at the same time.
And just to clarify, bore oil is also used in brass instruments to lube the valves and other moving components as well- I wasn't completely wrong!
-Ben
post #7 of 25 (permalink) Old 08-28-2003, 04:23 PM
Steel wool should never be used for cleaning regularly, you might as well just grab some 300 grit sandpaper to clean, and depending on how often you do, can probably imagine what you're doing to your fretboard.
Rich is offline
post #8 of 25 (permalink) Old 08-28-2003, 06:04 PM
No! I don't do that regularly... so far I've only done it when I get a really nasty fretboard on a new guitar acquisition. So actually, I've only done it a total of 2 times in 13 years
Otherwise, the fretboards get conditioned and cleaned w/ oil annually if they're lucky
-Ben
post #9 of 25 (permalink) Old 08-28-2003, 06:11 PM
"Cleaning" with oil just takes the crud into the pores of the wood with the oil, it is not meant to be used for cleaning, only conditioning
Rich is offline
post #10 of 25 (permalink) Old 08-28-2003, 06:25 PM
Damnit I hate that you're always right! *shakes fist at the sky* Damn you!!
I must admit though, Formby's Lemon Oil Treatment does say "Cleans as it replaces wood's natural oils". But what you say seems logical and I'll go with your suggestion.
Thanks (again) Rich!
post #11 of 25 (permalink) Old 08-28-2003, 07:00 PM
Which like all Lemon Oil is really formulated for "furniture", and one thing all furniture has in common, it's "finished", not raw wood
Rich is offline
post #12 of 25 (permalink) Old 08-28-2003, 07:42 PM
Hehe... you said "raw wood".
post #13 of 25 (permalink) Old 08-28-2003, 08:38 PM
UVmanMike is offline
post #14 of 25 (permalink) Old 08-28-2003, 09:09 PM
post #15 of 25 (permalink) Old 08-29-2003, 08:34 AM
Rich, it's o.k. to steel wool an Ebony fretboard right? I just got a Les Paul with an ebony board and it's FILTHY!! I did a couple of guitars that way (DBK/ Wolfgang) done just like your web-site shows and they came out great!! I DON"T do this method at all, just when I get a new/ used one. Thanks.......
bob mclaughlin is offline
ebony board , ebony fretboard , jem neck , les paul , steel wool
Neck cleaning questions Verus Tech: Setup, Repairs and Mods 14 02-14-2012 06:32 PM
Wizard III neck Cleaning Chris22 Tech: Setup, Repairs and Mods 2 01-30-2012 06:02 PM
Nooby Question: Cleaning the neck (not fretboard, neck!) mango_icecream Tech: Setup, Repairs and Mods 8 05-12-2008 09:03 PM
550 Neck cleaning??? poiter All Other Guitars (including Prestige) 3 02-15-2007 05:47 AM
HELP please! *DBK neck ussue - Have to figure out a solution Guitarlos2 Ibanez JEM, UV, JS & Other Signature Models 12 09-30-2001 10:55 PM
HTML code is On
