Differences between JS6 and JS700s? - Jemsite
post #1 of 9 (permalink) Old 08-17-2002, 07:35 PM Thread Starter
Reviews: 4
Well they're both mahogany w/out trems, right? Any other differences? I'm guessing the 700 was a Korean-made model by the "00" ending instead of the "000" ending. But is the 700 any good?
Ekim is offline
post #2 of 9 (permalink) Old 08-17-2002, 09:51 PM
Some 700s were Japanese made.
JESTER700 is offline
post #3 of 9 (permalink) Old 08-17-2002, 09:55 PM
EKG
JS6 - Fred and PAF Pro pups, maple neck, unfinished body
JS700 - P90 pups? and a mahogany neck? finished body?
EKG is offline
post #4 of 9 (permalink) Old 08-17-2002, 10:33 PM
the 6/6000 has the fixed strat bridge, the 700 the 'les paul junior' type
caprile is offline
post #5 of 9 (permalink) Old 08-19-2002, 04:57 AM
Loved my 700, but prefer the Japanese models cause I don't want the "Joe Satriani" inlay that the Korean model has. Japanese has "JS Custom" for the inlay
My only complaint would be the 700 has the back of the neck finished(same finish as the body). Plus if you change all the strings at once you gotta be careful cause the bridge can fall off very easily if your not careful!
Scott 74 is offline
post #6 of 9 (permalink) Old 09-05-2002, 12:22 AM Thread Starter
Reviews: 4
Can you go a little more into detail about the bridge falling out? I'm not getting it. And since I'm getting a JS700 in the mail in the next few days, I'd like a heads-up!
Ekim is offline
post #7 of 9 (permalink) Old 09-05-2002, 08:43 AM
The JS700 has a bridge comparable to a stop-bar tailpiece on a Les Paul. It's held on by the tension of the strings. Of course if you relax all of the tension at once, it'll come off. It just slides onto the mounting posts. Usually though, it's not the best idea to change all of your strings at once anyway, but it only takes a second to pop the tailpiece back into place if it does come off. Not really an issue.
vaijem777 is offline
post #8 of 9 (permalink) Old 09-05-2002, 10:01 AM
You could check with TonePros and see if they have locking studs that might fit the JS700's bridge. Apparently they improve the tone quite a bit, too, because it locks the tailpiece more securely to the studs.
darren wilson is offline
post #9 of 9 (permalink) Old 09-12-2002, 06:57 PM Thread Starter
Reviews: 4
Thanks for the advice. I might do that in a few months, when my cash flow situation has improved (and after I chuck two more of my unused snare drums onto EBay).
Ekim is offline
joe satriani , les paul , locking stud , locking studs , maple neck , neck finish , paf pro , strat bridge
Differences? Ericson All Other Guitars (including Prestige) 3 12-24-2012 11:49 PM
Lo-Trs and Lo-Trs 2 - What are the differences? SHREDlamode Archived Topics and Common Questions 11 01-09-2007 08:38 PM
JEM Differences cworley5150 Ibanez JEM, UV, JS & Other Signature Models 4 02-08-2006 10:00 AM
Differences? shredfreak All Other Guitars (including Prestige) 0 12-23-2005 05:18 PM
Differences between JEM, PGM and JPM - Only pu`s MrNiceguy87 Ibanez JEM, UV, JS & Other Signature Models 11 02-06-2002 02:41 PM
HTML code is On
