Dirty Volume Pot - Jemsite
post #1 of 15 (permalink) Old 01-21-2005, 08:13 AM Thread Starter
Arrow Dirty Volume Pot
A big round of applause for Algiman for helping me out with my previous problem (covered in my last thread).
There now seems to a noise that occurs when I adjust my volume (on my guitar). It sounds like a loose connection or something of the ilk (its not very loud , its a subtle sizzle).
How would I go about fixing that?
Jackhammer is offline
post #2 of 15 (permalink) Old 01-22-2005, 01:15 PM Thread Starter
Re: Dirty Volume Pot
Pfft.....
I hate doing this but... *Bump*
post #3 of 15 (permalink) Old 01-22-2005, 02:27 PM
Spray WD40 in it?
Azrael is offline
post #4 of 15 (permalink) Old 01-22-2005, 02:30 PM Thread Starter
In the volume knob?!
post #5 of 15 (permalink) Old 01-22-2005, 03:43 PM
Yup.....works for most potentiometers if I'm correct.....
Azrael is offline
post #6 of 15 (permalink) Old 01-22-2005, 07:22 PM
Originally Posted by Azrael
Spray WD40 in it?
No no no no no! A can of contact cleaner will do the job. Couple of quid and you're sorted.
Algiman is offline
post #7 of 15 (permalink) Old 01-23-2005, 06:17 AM
Yeah , but WD40 is a fine contact cleaner.....
Azrael is offline
post #8 of 15 (permalink) Old 01-23-2005, 07:38 AM
It is also a lubricant, and is too thick for fine electronics like this. It will work, but electronic contact cleaner would be better.
Algiman is offline
post #9 of 15 (permalink) Old 01-23-2005, 07:44 AM
Alright thanks for sharing. Will still work fine for my input jack though
Azrael is offline
post #10 of 15 (permalink) Old 01-30-2005, 10:35 PM
...and i hear it keeps the strings and hardware like new!
you can fix anything in the world with duct tape and wd40:
If it moves but it shouldn't - use duct tape.
If it doesn't move but it should - use WD40
Mo Fo is offline
post #11 of 15 (permalink) Old 02-04-2005, 12:31 PM
Smile Re: Dirty Volume Pot
I had a similar problem with my js1000btb - including the tone pot. I had both volume and tone pots changed under warranty, but this didn't solve the problem. Turns out that it's a static issue - when touching the strings, there's no crackle when pots tweaked. If not touching the strings, there's a crackle. No way round it I was told, but it's not a big problem (at least for me).
The Doctor is offline
post #12 of 15 (permalink) Old 02-04-2005, 01:55 PM
Paul Gilbert uses it.....
Azrael is offline
post #13 of 15 (permalink) Old 02-04-2005, 02:33 PM
The problem with WD-40 is that dirt sticks to it. This is why you have to wipe the excess off, when you spray it on anything. If you don't, the problem will only come back worse than before.
But, if Paul Gilbert uses it, then I guess he would know more than I would.
whatshisname is offline
post #14 of 15 (permalink) Old 02-08-2005, 04:06 PM
Paul Gilbert also plays drums. Use radio shack tuner cleaner.
jem7vwh93 is offline
post #15 of 15 (permalink) Old 02-09-2005, 07:33 AM
What's wrong with drums? Drums are awesome!
Azrael is offline
paul gilbert
Just a little dirty michblanch Off-topic / Miscellaneous 7 11-11-2008 07:28 PM
Your Dirty Dozen supermau Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 26 07-25-2006 09:44 PM
I feel dirty... UV_Ray All Other Guitars (including Prestige) 5 11-02-2005 01:54 AM
dirty 5 way switch Leary Tech: Setup, Repairs and Mods 3 09-01-2004 02:14 PM
Dirty pots in amp? PekkaM Gear, Equipment, Recording & Off Topic 6 07-29-2002 02:40 PM
HTML code is On
