Dropping in Edge in a JS routed for a LO pro. - Jemsite
post #1 of 10 (permalink) Old 07-12-2008, 01:44 AM Thread Starter
will it work? or will it need routing for the EDGE?
AmazinAzian12 is offline
post #2 of 10 (permalink) Old 07-12-2008, 02:02 AM
JayRobIBZ's Avatar
Reviews: 3
Re: Dropping in Edge in a JS routed for a LO pro.
I am no expert, but if memory serves me right, they are more or less interchangeable. That is to say that the routs are not identical but are close enough that you shouldn't have any problems.
I'd get an expert opinion though. It has been several years since I have owned a floating trem guitar and a lot of the Ibanez specific knowledge I used to have has faded away.
JayRobIBZ is offline
post #3 of 10 (permalink) Old 07-12-2008, 11:33 AM
Original Edge and Lo-Pro Edge are swappable without any routing required.
CityofBlindingLights is offline
post #4 of 10 (permalink) Old 07-12-2008, 06:44 PM
Usually, but not always. Not all Lo Pro routes have enough room at the back for the string lock screws on the Edge.
ryanb is offline
post #5 of 10 (permalink) Old 07-14-2008, 01:43 PM
Are the posts the same?
In my thread, some people were making it sound like there might be different spacing. Then again, I could have misunderstood...
Red43j is offline
post #6 of 10 (permalink) Old 07-14-2008, 04:33 PM
jb4674's Avatar
Reviews: 18
The posts are the same. The rout is similar because the tail of the lo-pro is actually longer than that of the edge's or they're equally just as long.
Jimmy
jb4674 is offline
post #7 of 10 (permalink) Old 07-14-2008, 07:55 PM
So Jimmy-
Can someone actually upgrade from having a LO TRS II to the current Edge Trem (sorry, I forget the name, but you don't have to cut the ball end of the strings off? Thanks Jimmy-Red43j
Red43j is offline
post #8 of 10 (permalink) Old 07-16-2008, 09:55 PM
jb4674's Avatar
Reviews: 18
From a Lo TRS II to an Edge Pro, I don't think so unless you want to mess with the routing and the posts to make it fit. If, however, the JS has an Edge Pro II, the Edge Pro will more than likely drop in without any problems.
Jimmy
jb4674 is offline
post #9 of 10 (permalink) Old 07-30-2008, 03:16 AM
the edge doesn't have a larger tail, thats an opticall illusion
seppe_sai is offline
post #10 of 10 (permalink) Old 08-11-2008, 11:20 AM
jb4674's Avatar
Reviews: 18
I didn't say edge, I said Lo-Pro.
Jimmy
jb4674 is offline
string lock , trem guitar
The official Name Dropping thread. Darin Off-topic / Miscellaneous 85 09-07-2009 04:15 PM
Thinking of dropping a floyd in... Matt08642 All Other Guitars (including Prestige) 7 09-12-2007 09:40 PM
Dropping EMG's into JEM7VWH latinjem7vwh Ibanez JEM, UV, JS & Other Signature Models 68 04-12-2006 07:04 AM
signal dropping on vwh dlp777 Ibanez JEM, UV, JS & Other Signature Models 2 01-25-2006 03:31 PM
Rear routed/mounted? Front routed/mounted? Jeff Tech: Setup, Repairs and Mods 19 10-07-2002 05:36 PM
HTML code is On
