edge 2 to edge - Jemsite
post #1 of 11 (permalink) Old 12-31-2006, 12:24 AM Thread Starter
edge 2 to edge
i've jus got mi ibanez edge trem and im in the midst of gettin the edge pro 2 trem out of mi jem 555(yes i noe its not a real jem). i've already taken the edge pro 2 and took out its stud. now i've got a prob, how to i remove the anchors of the edge pro 2 so tat i can put in the edge anchors? a fast reply would be good. thanks alot!
slash_88 is offline
post #2 of 11 (permalink) Old 12-31-2006, 12:33 AM
Re: edge 2 to edge
Screw the studs back in, grab each stud with a pair of pliers, and pull the anchors out. If you're worried about scratches wrap a rag around the stud before you yank the anchors out.
guitarman13 is offline
post #3 of 11 (permalink) Old 12-31-2006, 12:35 AM
Re: edge 2 to edge
Originally Posted by guitarman13 View Post
Screw the studs back in, grab the stud with a pair of pliers, and pull the anchors out. If you're worried about scratches wrap a rag around the stud before you yank the anchors out.
yeah that is pretty much the way it is done .
j.arledge is offline
post #4 of 11 (permalink) Old 12-31-2006, 01:06 AM Thread Starter
Re: edge 2 to edge
haha ok thanks guys. is it such a violent process? im realli scared of damaging the guitar.
slash_88 is offline
post #5 of 11 (permalink) Old 12-31-2006, 03:51 AM
Re: edge 2 to edge
Yup and there is a tutorial on projectguitar.com with pictures (though lo-trs II to Edge conversion).
Regards
André
fettouhi is offline
post #6 of 11 (permalink) Old 12-31-2006, 09:02 AM Thread Starter
Re: edge 2 to edge
thanks guys
slash_88 is offline
post #7 of 11 (permalink) Old 12-31-2006, 12:57 PM
Re: edge 2 to edge
It's not going to damage the guitar unless you don't do it the right way. Just gently pull and wiggle the studs out with the pliers.
post #8 of 11 (permalink) Old 12-31-2006, 01:14 PM
Re: edge 2 to edge
being a painted guitar, you might want to score the paint around the top of the posts with something very sharp before you try pulling the studs to minimise any chipping of the paint.
damo7v is offline
post #9 of 11 (permalink) Old 12-31-2006, 01:30 PM
Dino's Avatar
Re: edge 2 to edge
Don't matter, it's a 555! J/K
Dino is offline
post #10 of 11 (permalink) Old 01-01-2007, 12:13 AM Thread Starter
Re: edge 2 to edge
haha ok guys thanks for the reply, i've already added the edge in tot i still haven remove the the old edge pro 2 studs yet. got another big problem tot i was playin with the whammy bar yesterday and suddenly i got a bit violent with it and it broke(****!!!!!!!!!!!). now thers a piece of metal stuck in the whammy bar slot and i cant use the trem anymur unless i get that piece out . du u guys noe anyway of getting it out? is there a way of like looseing the slot so tat the metal piece will jus drop out?
slash_88 is offline
post #11 of 11 (permalink) Old 01-01-2007, 05:54 PM
Dino's Avatar
Re: edge 2 to edge
No, your screwed now! LOL! Get out the needle nose pliers!~
Dino is offline
edge trem , ibanez edge trem
Edge III swap for another Edge model trem? lespaulreedsmith All Other Guitars (including Prestige) 39 12-21-2017 06:11 PM
edge pro to lo pro rya Ibanez JEM, UV, JS & Other Signature Models 54 11-11-2012 03:24 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 08:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-13-2007 11:22 PM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 11:29 AM
HTML code is On
