Edge 7 saddles problem - Jemsite
post #1 of 2 (permalink) Old 04-05-2017, 04:38 PM Thread Starter
Edge 7, year 1990
Tried to change the strings, little black blocks that hold the strings on two saddles kept falling too deep in saddles
Removed them and found out that the bottoms of them are destroyed like on photo
Normal saddles' bottoms look like on photo
Can something be done about the problematic saddles or they are done and the only thing i could do is to get new saddles?
axis_musicman is offline
post #2 of 2 (permalink) Old 04-05-2017, 05:48 PM
Re: Edge 7 saddles problem
Use the saddles for the high strings. Here the screw does not need to be so far out when changing strings and the screw still holds the block.
Works for me on an old guitar on the high e.
Then again, a green dot could be worth two new saddles.
Cheers
J.
Jemerator is offline
FS- Edge-Zero Saddles dimitar Classified Ads: Guitars and Gear 0 06-16-2016 03:36 AM
EDGE Pro problem - saddles goe "tic tic" when I bend the high strings gitarrero Tech: Setup, Repairs and Mods 11 05-02-2012 05:58 PM
Edge saddles sssteve72 Tech: Setup, Repairs and Mods 1 11-28-2011 08:37 AM
Are Edge II, and EDGE III saddles the same?!? gemini8026 All Other Guitars (including Prestige) 5 01-19-2007 01:40 AM
Edge Saddles Are All The Same, Right? CrossingStar Tech: Setup, Repairs and Mods 5 07-24-2005 02:08 PM
HTML code is On
