Is this Edge angle's setup proper? - Jemsite
post #1 of 10 (permalink) Old 07-17-2006, 04:03 AM Thread Starter
Hi guys.
If you know more about Edge tremolos take a look at these pictures. Is it correct?
http://www.photobox.co.uk/album/albu...69216204&fit=1
http://www.photobox.co.uk/album/albu...69216205&fit=1
aenis is offline
post #2 of 10 (permalink) Old 07-17-2006, 04:13 AM
mi2tom's Avatar
Re: Is this Edge angle's setup proper?
Can't view the image
mi2tom is offline
post #3 of 10 (permalink) Old 07-17-2006, 04:27 AM
Can't see the pictures either. If you want to know if your trem angle is correct. Take look in the tech section of ibanezrules.com (banner above).
Regards
André
fettouhi is offline
post #4 of 10 (permalink) Old 07-17-2006, 04:48 AM Thread Starter
Sorry guys. I hope that you can see it now.
aenis is offline
post #5 of 10 (permalink) Old 07-17-2006, 05:21 AM Thread Starter
Well my concerns are basicly if you look at this picture (I took it from the Jemsite) if you see the little square marker (in blue) does it need to be just above the body on the Low E string side and as well on the High E string side?
In my case the low E side is just like on the picture but i doesnt shows on the high E side of the bridge. (see pictures above in my previos post)
aenis is offline
post #6 of 10 (permalink) Old 07-17-2006, 05:26 AM
Jaden's Avatar
im no expert but i set my trems up like that and have no problems.
the high and low e's will rarely (in my limited experience) be set at the same height.
that setup looks fine - maybe the pups are a little close to the strings though
Jaden is offline
post #7 of 10 (permalink) Old 07-26-2006, 03:52 PM
String height is a personal pref but the mark detailed above should be level. For the pu height, you've got to find the sweet spot for the pick-up and your playing style.
Team J Crafter is offline
post #8 of 10 (permalink) Old 07-26-2006, 05:20 PM
looks good, a little to low , if I set it up that low I get some fret buzz on my 550.
Ozzdoc is offline
post #9 of 10 (permalink) Old 07-26-2006, 08:21 PM
That looks almost exactly where my edge is, and she works fine, so I'll say yes!
ChopTart is offline
post #10 of 10 (permalink) Old 07-26-2006, 08:53 PM
If the lil rectangular thing shows on one side but not the other, then it would seem that one post is higher than the other... i wouldnt like that, as it would mean the low E is waaay higher than the high E... (how confusing was that?? )
i like my strings even in height, so my bridges are as parallel to the body as i can get them...
marianozz is offline
edge trem , fret buzz
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 08:35 AM
Edge Pro II swap into an Edge Pro trem??? Flame_Virtuoso_6688 All Other Guitars (including Prestige) 0 07-18-2005 06:01 PM
The Edge II and the FR Speed Loader Flame_Virtuoso_6688 All Other Guitars (including Prestige) 0 06-16-2005 04:38 PM
Lo Pro Edge vs Edge - differnece between these trems YngVaiTriani Gear, Equipment, Recording & Off Topic 21 08-01-2001 07:37 PM
Changing string gauges - What's to be setup again ? Wicked Blade Tech: Setup, Repairs and Mods 2 04-22-2001 01:21 PM
HTML code is On
