Edge pro help - Jemsite
post #1 of 6 (permalink) Old 12-23-2009, 03:08 PM Thread Starter
Edge pro help
I have an Edge pro bridge that Id like to put to use. Does anyone know what model RG's came with the edge pro bridge? I tried to get it into a lo pro route but its different. Thanks everyone!
carbons2k is offline
post #2 of 6 (permalink) Old 12-23-2009, 03:53 PM
Ayrton's Avatar
Re: Edge pro help
1570 was the most common, and you can find those bodies all over the bay.
I even have a loaded one cheap if you need another.
Ayrton is offline
post #3 of 6 (permalink) Old 01-02-2010, 08:54 PM
Re: Edge pro help
How was it different? The Edge Pro should have set in to a Lo Pro cavity....I think.
Was it too big for the cavity ?
darrenw5094 is offline
post #4 of 6 (permalink) Old 01-02-2010, 11:47 PM Thread Starter
Re: Edge pro help
yea, the block under the bridge doesnt fit all the way thru the body.
post #5 of 6 (permalink) Old 01-03-2010, 12:05 AM
Reviews: 10
Re: Edge pro help
the edge pro as i'm sure you know by now requires a completely different cavity route to occomidate the bridge vs. a lo pro. take your guitar to a reputable luthier with schematics of the cavity route and see if the lo pro route can be modified. or buy another body as previously stated.
bhuard75 is offline
post #6 of 6 (permalink) Old 01-03-2010, 08:50 AM
Re: Edge pro help
The only issue should be the trem block. Other than that, the posts are in the right place and the cavity from top of body is big enough.
FT Ibanez Edge Pro Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 2 12-02-2009 11:05 AM
FT Ibanez Edge Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 1 06-26-2009 05:45 PM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 09:16 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 01:18 PM
HELP URGENT ! I need an EDGE PRO or EDGE PRO II floyd ! + some black screws tchintao Classified Ads: Ibanez JEM/UV Guitars 3 02-24-2005 12:31 PM
HTML code is On
