Edge Pro Locking Studs Help - Jemsite
post #1 of 9 (permalink) Old 09-01-2013, 11:13 AM Thread Starter
First off I'm a newb to the site and have searched 75 or so pages looking for info on this but can't seem to find what I need. Even checked Youtube but found nothing on the subject.
Here's my situation:
I have an older JS100 and I'm looking to install an Edge Pro trem. I have seen mention of the locking stud mod but I am completely in the dark about what it really is and why it's needed let alone how to perform the mod. I am also in the dark about which shims are needed to match the neck radius on the JS100.
The forum provides a lot of insight and help so I hoping someone could explain what I need to know or point me to a source for help.
Thanks
DGoodluck is offline
post #2 of 9 (permalink) Old 09-01-2013, 02:04 PM
Re: Edge Pro Locking Studs Help
Rich has a great explaination on his site:
http://www.ibanezrules.com/tech/setup/stud_mod_03.htm
Not done this on a JS but I did do this on my 03 JEM and Universe and tuning stability is much better.
Mattww is offline
post #3 of 9 (permalink) Old 09-01-2013, 02:20 PM
In addition to what was said above, you may also need to make the trem cavity bigger to accommodate an Edge Pro.
I had a JS100 at one and started looking into upgrading it. By the time I started factoring all the costs (time and money) relative to the end product that I would end up having, I decided my best option was to sell my JS100 and use that money along with the money I would have put towards the upgrades to buy a used JS1000. In the end, I probably spent a few hundred bucks extra and have a far superior guitar that I'm completely happy with. If I ever decided to part with my JS1000, I will probably likely get all or most my money back (since it was a used guitar purchase to begin with) whereas you likely wouldn't recoup most of your costs if you later decided to re-sell the JS100. Unless you are seeing this as a bit of a hobby/fun project which has its own merits, I would recommend selling your JS100 and finding a used JS1000 or JS1200.
jemeister is offline
post #4 of 9 (permalink) Old 09-01-2013, 04:04 PM
Do you have an Edfge II or a RTS trem in you JS100?
sebastian is offline
post #5 of 9 (permalink) Old 09-01-2013, 04:50 PM Thread Starter
Thanks Matt, I didn't think to look at Rich's site for the answer - it should have been obvious.
Jemiester, I hear what you're saying and thanks for the advice but I've already got the trem, upgraded the electronics, pickups, replaced the tone pot with a toggle for coil splitting, reftretted the board and sanded the neck to perfection. It actually plays and sounds as good as the 1000 I lost in a fire back in '08 but the trem sucks a$$.
post #6 of 9 (permalink) Old 09-02-2013, 01:35 PM Thread Starter
It's a Lo-TRS Trem II.
post #7 of 9 (permalink) Old 09-02-2013, 03:50 PM
The trem does suck. I seem to remember looking into swapping it out with an Edge Pro before as well. The locking studs for the Edge Pro will make a vast improvement in the tuning stability.
post #8 of 9 (permalink) Old 09-02-2013, 04:15 PM
I've only had one guitar with a Lo TRS, JS100.
I never pulled the studs or put in a different trem.
If the anchors are different, they'll have to go.
You'll have to wrap a 1/2 or 3/4 board in a towel and set it on the top of the guitar.
Then thread the stud out enough so you can get a claw hammer on it.
Then pull it out slowly.
If the hole is smaller you'll need a 10mm metric drill bit to open it up for the new anchors.
I got a cheap 10mm drill bit from China on Ebay for like $3.
I use it to clean paint out of the stud holes after they get painted.
I keep an out beat up stud around, a long one from an old RG from the 80s.
I put it in the new stud to pound it in all the way without hitting the body.
I also use it to pull studs from bodies.
post #9 of 9 (permalink) Old 09-02-2013, 05:06 PM Thread Starter
Sebastian thanks for the heads up and tips on pulling the anchor if that's needed - I really hope it isn't. Seems it would be pretty easy to oblong the anchor hole and make a mess of things....
edge pro , js100
Edge Pro locking studs Alfi27 Tech: Setup, Repairs and Mods 4 04-07-2013 04:32 PM
Locking Studs on Edge Pro's ChrisPcritter Comments to Ibanez 12 01-14-2009 06:31 AM
Edge Locking studs help martyfriedman86 Tech: Setup, Repairs and Mods 25 03-16-2008 01:02 PM
why can't the OFR use the Edge's locking studs? MetalWarrior Tech: Setup, Repairs and Mods 9 09-30-2006 10:29 PM
locking studs on an edge pro? champ222 Tech: Setup, Repairs and Mods 2 02-13-2006 09:41 AM
HTML code is On
