Edge Pro replacement for JS100? - Jemsite
post #1 of 7 (permalink) Old 03-03-2015, 05:34 PM Thread Starter
Smile Edge Pro replacement for JS100?
So I was wondering if the Edge Pro can be used to replace the Edge III in my JS100? Is it a direct drop in or does it need extra routing, and also are the threads of the posts the same thickness.
Thanks
VAI2K is offline
post #2 of 7 (permalink) Old 03-04-2015, 07:29 AM
Re: Edge Pro replacement for JS100?
To best of my knowledge, the route is the same, but the posts' thread-to-thread spacing different as well as the post anchor diameter. I think most people use the edge III posts as Edge Pro posts are non locking like the Edge III posts.
kissTheApex is offline
post #3 of 7 (permalink) Old 03-04-2015, 09:00 AM
I can't speak for the Edge III, but I know the old Lo-TRS used in the JS100 could be swapped for an Original Floyd Rose. Having played both extensively, the difference between an OFR and an Edge is largely a matter of preference - both are excellent trems.
Drew is offline
post #4 of 7 (permalink) Old 03-04-2015, 07:06 PM
Reviews: 21
I don't know about the JS route but I know Edge Pro drops right in on an Edge3 route on an RG. I've done it before.
mike570 is offline
post #5 of 7 (permalink) Old 03-05-2015, 06:26 AM Thread Starter
I also have an RG with the Edge III, I'll check the route on both and compare measurements to see if it's possible. Well at least I know I can upgrade my RG's bridge too, without worrying about needing to change anything. Thank you.
VAI2K is offline
post #6 of 7 (permalink) Old 03-05-2015, 12:45 PM
Another thing to consider would be if the Edge pro would need some shims to match the neck radius, i'm not sure about the JS100 but on my JS1000/1200 both the OE and Lo Pro are shimmed under the saddles.
Rafafas is offline
post #7 of 7 (permalink) Old 03-05-2015, 01:30 PM
Reviews: 21
Great point!
mike570 is offline
edge pro , ibanez , joe , js100 , satriani
JS100 Trem Replacement Suggestions jmbjsx2000 Ibanez JEM, UV, JS & Other Signature Models 16 03-01-2012 10:21 AM
JS100 bridge swap??? Edge Pro / Edge Pro II n7uqa Ibanez JEM, UV, JS & Other Signature Models 8 06-04-2009 11:35 AM
Replacement machinehead suggestions for JS100? pimpmysatch Ibanez JEM, UV, JS & Other Signature Models 2 10-28-2008 11:50 AM
Can i change an Edge Pro 2 for an Edge Pro on a JS100??? ProgOn Ibanez JEM, UV, JS & Other Signature Models 5 01-21-2007 11:15 PM
HTML code is On
