Edge replacement for a Floyd??? - Jemsite
post #1 of 7 (permalink) Old 02-12-2015, 10:41 PM Thread Starter
I'm curious. Can you replace an Original Floyd Rose with an Original Edge 250mm tremolo without having to route the guitar?? Also, the guitar in question has a 10" fretboard radius, that's why I'm asking about the JS Edge 250mm. Am I right to assume that would work better with a 10" radius than the regular Original Edge Trem?
monnkey2 is offline
post #2 of 7 (permalink) Old 02-13-2015, 06:45 PM
RGTFanatic's Avatar
Re: Edge replacement for a Floyd???
If you can find an Edge that speciffically came out of a JS, it MIGHT work- but doubtful.
What guitar are you looking to put an Edge into?
RGTFanatic is offline
post #3 of 7 (permalink) Old 02-13-2015, 07:06 PM Thread Starter
Thinking about doing it in a Carvin DC400W
monnkey2 is offline
post #4 of 7 (permalink) Old 02-14-2015, 12:27 AM
If the trem fits the guitar, I believe you can adjust the radius with shims under the saddles. I believe that's how it is done in the JS as well...
jazzedout is offline
post #5 of 7 (permalink) Old 02-14-2015, 05:27 PM
I'm pretty sure you'll have to modify the route. Whether you'll go for chisel/sand/elbow grease or route is up to you.
OFR routing template shows an overall length of 3.125" vs. 3 5/16" of Edge. On the OFR, overall minus the fine tuner length is 1.6707" vs slightly over 1.75" on the Edge, so you'll definitely have to modify the main pocket and the fine tuner pocket. One other matter is the studs/stud anchors. OFR stud anchor diameter is slightly over 10 mms (0.3938" as listed on OFR routing diagram) and 20.32mm deep, while the Edge stud anchors are 11.3 mms and roughly 25 mm (I first thought 30, but went back and check and it is) deep. Stud distance for both are roughly the same, so you might be able to get away with using the OFR studs/stud anchors.
I'm assuming the guitar you have now has a recessed route, hence the comparison above, but if it doesn't, the conversion should be much easier as the block locations seem to match closely. You may have to sand the trem bar side of the route a bit but it should be much less work than the above, if any.
I hope this helps.
Last edited by kissTheApex; 02-14-2015 at 05:54 PM. Reason: Edge Stud Anchor Length Correction
kissTheApex is offline
post #6 of 7 (permalink) Old 02-14-2015, 07:31 PM
99% sure this is the case as well, with respect to shims.
I've never replaced an OFR with an Edge, but I've done the reverse - my UV7PWH has an OFR in place of the original LoPro Edge it shipped with (that was falling to pieces when I got this guitar). It was pretty tight on the treble side and took a little bit of attention with a file so it wouldn't rub, but otherwise worked flawlessly.
Drew is offline
post #7 of 7 (permalink) Old 02-15-2015, 01:59 PM
RGTFanatic's Avatar
Looking at the specs, your DC400 should have a 14" radius (355mm). No matter which Edge you find, you'll have to do some shimming.
IIRC, the Edge pro fits into a standard OFR route.
edge , floyd rose
Floyd Rose Special or Pro as a Lo TRS-II replacement? tlhamon51 Tech: Setup, Repairs and Mods 12 06-25-2012 05:03 PM
Jackson Licensed Floyd replacement Getaspacejob All Other Guitars (including Prestige) 5 08-22-2010 09:02 PM
Replacement Arm Holder - Ibanez -> Floyd possible? chimera963chris Tech: Setup, Repairs and Mods 0 11-13-2009 07:41 AM
Jem 555 W/ Orginal Floyd Rose Replacement??? Epicus Furor Ibanez JEM, UV, JS & Other Signature Models 2 07-08-2005 02:02 PM
floyd type strat replacement the.godfather Tech: Setup, Repairs and Mods 3 11-12-2003 01:27 PM
HTML code is On
