Egde Pro on JEM-555WH - Jemsite
post #1 of 28 (permalink) Old 03-03-2008, 02:34 AM Thread Starter
Smile Egde Pro on JEM-555WH
Hello,
for my Ibanez JEM-555WH (2006)
is it possible to install a vibrato EDGE PRO on my guitar ?
because my vibrato EDGE PRO II is 'tired'
the ARM is too Floating
Thanks,
mb
musbing is offline
post #2 of 28 (permalink) Old 03-03-2008, 02:53 AM
Re: Egde Pro on JEM-555WH
i had a 555 for 11 years.spent most of that time tuning in (lo-trs11).i swapped it for a line6 flextone amp ahhhh best thing i ever did.
rob777vdy is offline
post #3 of 28 (permalink) Old 03-03-2008, 03:36 PM
an OFR is a direct swap..youre better off with that cause you have to route wood for an edge pro
isaac is offline
post #4 of 28 (permalink) Old 03-03-2008, 07:51 PM
isaac is correct. I have done this mod but if you are not really good with routing, I recommend you do not attempt it. If you want to details, shoot me an email.
albee1952 is offline
post #5 of 28 (permalink) Old 03-03-2008, 07:52 PM
yu don´t have to rute for an edge pro but yo do have to if you put an OFR there
rvai is offline
post #6 of 28 (permalink) Old 03-04-2008, 01:42 AM Thread Starter
thanks for you reply,
OFR = Original Floyd Rose
Schaller is the manufacturer ?
http://schaller-guitarparts.de/hp263...los-_-Nuts.htm
What's model, “Floyd Rose” Tremolo or Low Profile Tremolos ?
musbing is offline
post #7 of 28 (permalink) Old 03-04-2008, 02:46 AM Thread Starter
On this site he speaks of a swap of vibrato ibanez
http://lawl.net/gtr/trems
LoTRS I/II: most famously known to be replaced with the Original Floyd Rose or Gotoh FR. If you are replacing the studs, you will need to drill your guitar to accomodate the new bigger studs.
Edge Pro II: swaps with the Edge Pro. The locking stud mod is also recommended.
Edge III: swaps with the Original Floyd Rose. Stud rule applies, OFR studs are bigger. Additionally, there is a variation in Edge III routes that prevent the easy swap in some series.
musbing is offline
post #8 of 28 (permalink) Old 03-04-2008, 07:02 AM
Not correct i have a 555 with OFR No probs just insert it no routing or changeing Studs... Will fit right in...Stayed in tune for 6 month now and still are.
Glados is offline
post #9 of 28 (permalink) Old 03-04-2008, 07:41 AM Thread Starter
Hello,
your Trem is Original Floyd Rose (see the model) ?
http://www.floydrose.com/original.html
It is important to have the right model...
musbing is offline
post #10 of 28 (permalink) Old 03-04-2008, 05:12 PM
Originally Posted by musbing View Post
Hello,
Hello
Yeah i have the same as van Halen had.
It was on a 80's kramer the OFR is Made in Germany.
Mrvai said you have to route the swap to OFR on a 555 And i said for OFR you can put i right in... Thats it.
Glados is offline
post #11 of 28 (permalink) Old 03-19-2008, 03:31 AM
i bought a lo pro edge on evilbay and it fit right in my jem 555bk from 1996. Holds tune just fine...
trixdropd is offline
post #12 of 28 (permalink) Old 03-19-2008, 11:36 PM
Here is my 555. changed the trs for an edge tremolo. now i call it JEM557
Claudio Passamani is offline
post #13 of 28 (permalink) Old 03-20-2008, 04:24 AM
the edge tremolo work's without modification?
groove87 is offline
post #14 of 28 (permalink) Old 03-20-2008, 12:26 PM
well here it fits normally without mods.. i heard that we have to change the studs and remake the stud holes.. but i gently put the edgre on the trs studs and the thing worked.. the tremolo dont touch the wood and the screws fit in tremolo cavity.. that peculiar "slap the whammy bar" effect, so good in the edge tremolos are not so efective.. im considering change the studs too.. but the guitar is working on tune.. perfectly..
post #15 of 28 (permalink) Old 03-20-2008, 01:48 PM
jb4674's Avatar
Reviews: 18
Wrong.
Wrong.
The swap to an Edge Pro is the most logical one if the guitar is equipped with an Edge Pro II. The swap is doable because both trems are similar in dimensions and the route is the same.
Jimmy
jb4674 is offline
edge trem , floyd rose , ibanez edge pro , ibanez jem , kahler trem , locking stud , locking stud mod , pro edge , tremolo cavity , trs bridge , van halen
Similar Searches
Who to sharper a knife egde
Transcript of Aussie Vai I'view (didnt know where to put it) TheOrangeChannel Ibanez JEM, UV, JS & Other Signature Models 16 07-25-2006 11:52 PM
F/S or trade jem 555wh steve vai 777 Classified Ads: Guitars and Gear 6 03-06-2005 02:18 PM
Greetings, from this new JEM owner! kingtj Ibanez JEM, UV, JS & Other Signature Models 7 08-11-2004 12:45 PM
Nice story to tell - How I've found a JEM 10 jember Ibanez JEM, UV, JS & Other Signature Models 9 03-20-2002 05:22 PM
A little problem with my JEM 555WH - I've already seen this carlos seo Ibanez JEM, UV, JS & Other Signature Models 8 03-01-2001 11:54 AM
HTML code is On
