Excessive wear of flat blade? - Jemsite
post #1 of 16 (permalink) Old 07-26-2004, 09:31 PM Thread Starter
UV
My Jem7dbk has really bad wear of the flat blade. It's 2 years old and the blades are a different color than my 2 UVs which are both over 10 years old and fine. A PWH and a 777GR. Help! It is set up totally neutral.
U
v
UV is offline
post #2 of 16 (permalink) Old 07-26-2004, 10:00 PM Thread Starter
UV
The blades in my UVs are black, the Jem blades are chrome or silverish.
U
v
UV is offline
post #3 of 16 (permalink) Old 07-26-2004, 11:12 PM
Just as they're supposed to be........
Rich is offline
post #4 of 16 (permalink) Old 07-27-2004, 03:43 PM Thread Starter
UV
Ok, so do you recommend filing them or should I just buy a new plate with new blades and some new studs?
U
v
UV is offline
post #5 of 16 (permalink) Old 07-27-2004, 03:53 PM
All you've said is one is silver [it's supposed to be, it's CHROME] and one is black [it's supposed to be, it's not chromed].
Rich is offline
post #6 of 16 (permalink) Old 07-27-2004, 04:11 PM Thread Starter
UV
I said in the first post that the flat blade in my Jem had excessive wear. It looks like it's burred. I had a spare bridge that I bought for parts years ago and swapped the whole thing out and put the new studs in and the guitar is fine now. It's cosmo black though so I'd like to repair the original and put it back on the guitar. I guess I'll need some new posts. If the blade is that messed up the post must be ratty too. Suggestions? Does anyone press new blades into base plates or do I have to buy a new one?
U
v
UV is offline
post #7 of 16 (permalink) Old 07-27-2004, 04:14 PM
Re: Excessive wear of flat blade?
U
v
Sorry, nothing about a burr here. You can file it out, new studs if you want, but the studs are much harder than the knifes are.
Rich is offline
post #8 of 16 (permalink) Old 07-27-2004, 04:22 PM Thread Starter
UV
Sorry that I wasn't clear. Can a new plate with new blades be bought? Or new blades pressed into the old one? The rest of the bridge is like new.
U
v
UV is offline
post #9 of 16 (permalink) Old 07-27-2004, 04:25 PM
It would require more skill to replace the knives than it will to file it correctly.
Rich is offline
post #10 of 16 (permalink) Old 07-27-2004, 04:32 PM Thread Starter
UV
I know that you sell parts, do you also do repairs? I really don't have the tools or know how to start filing the blades.
U
v
UV is offline
post #11 of 16 (permalink) Old 07-27-2004, 07:54 PM
I do some ship in work, but the shipping just makes it more expensive and not usually the best alternative.
Rich is offline
post #12 of 16 (permalink) Old 07-27-2004, 08:39 PM Thread Starter
UV
I'm in Staten Island so shipping would be negligable. I have no problem sending you the bridge if you are willing to fix it. Let me know. I can order some parts at the same time.
U
v
UV is offline
post #13 of 16 (permalink) Old 07-27-2004, 09:08 PM
Priority mail doesn't care how far you are, it'll still be $8 each way to send a trem insured.
Rich is offline
post #14 of 16 (permalink) Old 07-27-2004, 09:12 PM Thread Starter
UV
I think that I can spring for it.
U
v
UV is offline
post #15 of 16 (permalink) Old 07-27-2004, 09:14 PM
It's your money, email me
Rich is offline
base plate
Removal of excessive crud? Jacob K Tech: Setup, Repairs and Mods 14 11-25-2008 01:06 PM
Flat tax is a 23 percent flat tax on bought goods possible? Clonetool Off-topic / Miscellaneous 7 08-07-2007 12:31 PM
Challenged Seller On Perceived Excessive Shipping Charges. Should I Feel Bad? CrossingStar Vendors, Auction & Reseller Talk 18 07-05-2005 09:51 PM
Excessive stretching of High-E string on lo-pro BluewookieJim Tech: Setup, Repairs and Mods 8 02-23-2003 09:00 AM
Excessive string breakage...HELP!!! - On my Lo-Pro equipped Patrick Deno Ibanez JEM, UV, JS & Other Signature Models 14 06-17-2001 05:39 PM
HTML code is On
