F-space or regular ??? - What do I need for a jem 10th ?? - Jemsite
post #1 of 6 (permalink) Old 01-08-2002, 04:22 PM Thread Starter
I am gonna buy new pickups for my jem 10th, F-space or regular???
What is the difference ?
BronzeMan is offline
post #2 of 6 (permalink) Old 01-08-2002, 06:17 PM
F-Spaced basically means the pole-pieces will line up correctly underneath the strings of a fender trem (or Floyd, edge, lo/pro, wilkinson etc....)
To put it simple, the majority of trems utilise F-Spaced pups for optimum alignment as opposed to hardtails which usually line up best with standards.
Basically it means Fender set the standard which dictated what most have to use (think staggered single coils etc...)
Bear this in mind though,
if you are really *an4l
(like me) you'll find that most line up best with an F-Spaced bridge pup and a standard spaced neck pup.
Steve
(Edited by ripl3y at 6:20 pm on Jan. 8, 2002)
ripl3y is offline
post #3 of 6 (permalink) Old 01-08-2002, 10:17 PM
kennydoe's Avatar
ripl3y on 6:17 pm on Jan. 8, 2002
Bear this in mind though, if you are really *an4l
(like me) you'll find that most line up best with an F-Spaced bridge pup and a standard spaced neck pup.(Edited by ripl3y at 6:20 pm on Jan. 8, 2002)
I've always done F-Spaced in the Bridge and standard at the neck. * I just thought that's how it was supposed to be. *I never had any problem.
~K
kennydoe is offline
post #4 of 6 (permalink) Old 01-09-2002, 12:44 PM
In my experience, i always use an F-space on the bridge, and a regular on the neck. You can put an F-space on the neck, but it doesn't really matter. Eighther kind work good; but defenitely an F-space for the bridge.
johnjohn969 is offline
post #5 of 6 (permalink) Old 01-09-2002, 01:04 PM
I have an F-spaced Tone Zone in the bridge and and F-spaced Air Norton in the neck of my Jem and they both sound good to me! *I don't really think you could go wrong either way soundwise though.
jem777az is offline
post #6 of 6 (permalink) Old 01-09-2002, 02:05 PM
Check out this thread for some alternatives to replacing the pups.
http://jemsiteforum.com/board/topic....=173&replies=6
Rich is offline
air norton , bridge pup , neck pup , tone zone
MutationEight by Space Monkey and the Space Monkeys Kilar Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 10-22-2011 11:21 PM
Space Monkey and the Space Monkeys Kilar Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 05-29-2008 07:24 PM
Help on replacing pickups - To F-space or not to F-space? ashlock Archived Topics and Common Questions 10 01-07-2002 06:17 PM
whats the difference between an F-Space pickup and a regular AJ Love Tech: Setup, Repairs and Mods 2 08-09-2001 02:32 AM
Help on replacing pickups - To F-space or not to F-space? ashlock Ibanez JEM, UV, JS & Other Signature Models 9 03-12-2001 03:51 PM
HTML code is On
