few JS1000 questions - Jemsite
post #1 of 6 (permalink) Old 01-27-2003, 01:44 AM Thread Starter
Hey guys,this is jimbojim from satriani.com..I have acquired a JS1000 a few months ago I have to say that I love it ...but I have a few questions.
1st-I think my trem bar is too loose,it plays perfectly,I can play with the trem without any problem but it bugs me that I can'T keep it parallel with the strings,it always falls and points the ground,is there a way to avoid that?is this something good or bad?
2nd-How can I remove my fringerprints??I tried with napkins,etc..it just 'spreads' em...I want to keep my guitar clean.
3rd-Is it possible to avoid the strings to 'detune' when I bend a string..'exemple I bend the 3rd string,while I keep the string bent,when I play 2nd string the note will be somewhere between B and Bb.When I'm done bending,it goes back to perfect B...it doesn't bug me that much,just trying to know if there is a way to avoid it
Thanks folks..
Rémy
p.s sorry for the 'avoid' repetitions...lol
jimbojim is offline
post #2 of 6 (permalink) Old 01-27-2003, 02:17 AM
Sounds like the white plastic bushings on the trem bar are worn,get some from an ibanez dealer.Ever clean your sunglasses by breathing on them? Works good for fingerprints too.I also use rubbing alcohol when the breath thing doesn't work.As far as doing a double bend,you will get used to it.The one disadvantage of a floating trem is the slight pitch change when bending,I just tend to compensate for it because i'm used to it.For more setup info,click the ibanez rules banner up above or do a forum search.Nice guitar,by the way.Welcome.
musicdr is offline
post #3 of 6 (permalink) Old 01-27-2003, 03:07 AM Thread Starter
thanks alot for your answers...can't I get a trem bar that will fit into my js in any guitar store?
jimbojim is offline
post #4 of 6 (permalink) Old 01-27-2003, 08:38 AM
chromeboy's Avatar
Changing the white plastic bushing on the bar should tighten it up, you probably don't need a new bar.
Also, for the fingerprints and polishing, pick up a guitar polishing cloth from a music store, they're soft and are treated.
You have a floating trem on the guitar, so there's no way to avoid "detune" when you bend your strings, unless you block your trem.
Have fun with your JS!
chromeboy is offline
post #5 of 6 (permalink) Old 01-27-2003, 12:20 PM
You guys haven't been paying attention
Add a 4th or even 5th spring depending on how much you want it to stay in tune under bending. Obviously the feel is going to change but your strings will stay in tune better. Joe uses 2 springs in an arrow, but they aren't stock springs, his 2 feel like at least 4 regular springs.
I keep bar bushings in stock.
Rich is offline
post #6 of 6 (permalink) Old 01-27-2003, 10:09 PM
1. bushings bushings bushings will keep your bar where you want it.
2. Your breath is free, anything else you have to pay for it
3. If you want your other strings to stay in tune, get a Js2000......or you can get real good at applying slight downward pressure with the palm of your picking hand on top of the bridge when your bending strings and then playing other strings.......to try and keep the pitch in tune......you have to do it a lot to get used to it. Putting more springs would just make bending more of a chore and strings will feel stiffer. But the best way to eliminate strings going out of tune while bending, is to get a fixed bridge
SilverSurfer2 is offline
fixed bridge , ibanez dealer , music store
First Post: JS1000 Questions! Monsta-Tone Ibanez JEM, UV, JS & Other Signature Models 6 01-07-2012 03:47 PM
First JS1000 - Couple Quick Questions Superman859 Ibanez JEM, UV, JS & Other Signature Models 12 05-14-2009 02:35 AM
JS1000 Questions vmann Ibanez JEM, UV, JS & Other Signature Models 3 04-17-2008 10:01 PM
If I buy a used JS1000....questions??? Axe Chemist Ibanez JEM, UV, JS & Other Signature Models 1 03-31-2008 08:54 AM
JS1000 questions satchmo Ibanez JEM, UV, JS & Other Signature Models 9 10-17-2007 05:10 PM
HTML code is On
