Fitting an Edge trem in a 555 - Jemsite
post #1 of 8 (permalink) Old 04-13-2003, 03:26 PM Thread Starter
I got a Jem555 and i love the neck and feel of it much better than my RGs for some reason. But I absolutely hate the trem so Im thinkin a buying an edge trem, will i have to chop any timber to fit it or will it just slot in, and if i will are their any trems that are better than the TRS that fits straight in
Thx Padraig
padraig is offline
post #2 of 8 (permalink) Old 04-13-2003, 04:42 PM
The new 2003 Edge Pro tremelo won't fit on older models, so for sure you can forget about that.
I'm not sure about older models though. Maybe you might be able to fit a 2002 Edge or something, but once again, not sure about that.
Ravager is offline
post #3 of 8 (permalink) Old 04-13-2003, 04:55 PM
Super Moderator
I'm fairly sure that this has been discussed before and the topics should be still available using the SEARCH facility.
Some folks have been able to fit an Edge trem without routing the bodies others haven't.
Your milage may vary.
jono is offline
post #4 of 8 (permalink) Old 04-13-2003, 06:43 PM
I'm not so sure about that. The redesigned Edge trems seem to have a very similar rout as the older TRS trems. Does anyone here know for *sure* that the new trems won't fit in the older TRS cavities?
~d~
dcord is offline
post #5 of 8 (permalink) Old 04-13-2003, 07:49 PM
http://www.jemsite.com/axes/htm_features/trems.htm
scroll to the bottom of the page.
Traveler in Pain is offline
post #6 of 8 (permalink) Old 04-13-2003, 08:21 PM
I think that guide is meant for the 2002 Edge and Low-Pro. They 2003 version will not fit on an older model JEM, so I doubt that it would fit into a TRS cavity.
Ravager is offline
post #7 of 8 (permalink) Old 04-13-2003, 08:47 PM
You've tried the swap then, or at least gotten measurements? I am sincerely interested in the measurements of the new trems, and how they differ from the previous models so could you pass that info along? Thanks in advance.
As far as the guide on Jemsite, Ravager is correct - that applies to the 2002 and prior Edge models.
~d~
dcord is offline
post #8 of 8 (permalink) Old 04-13-2003, 08:52 PM
site founder 0% owner
jemsite's Avatar
They don't retrofit.
http://www.jemsite.com/news/edge2003/index.htm
...glen
jemsite is offline
Closed Thread
edge pro trem , edge trem , edge trems , trs trems
FS: Double Edge Trem (piezo equipped trem) Guitarmattms Classified Ads: Guitars and Gear 0 01-23-2014 10:12 PM
Need help with edge trem fitting on an Rg535 IbanezFreak777 Tech: Setup, Repairs and Mods 1 08-01-2008 11:35 PM
Fitting trem inserts. Zoot Tech: Setup, Repairs and Mods 4 06-10-2007 08:51 PM
FT: Black Cosmo Lo-Pro Edge Trem for your Chrome Lo-Pro or Original Edge Trem parker_fly Classified Ads: Guitars and Gear 4 02-19-2005 03:18 PM
HTML code is On
