Floyd rose problems! - Jemsite
post #1 of 8 (permalink) Old 06-16-2010, 07:20 PM Thread Starter
Just purchased a JEM 77FP, its amazing, apart from now i have been playing a while i noticed that the low E string is considerably lower than the others! Does anyone know how to fix this problem? Is it something to do with the saddles? The intonation is fine however the guitar does have a low action. There is just a buzzing noise when ever a fretted note on that string is played.
Vegnjame is offline
post #2 of 8 (permalink) Old 06-16-2010, 08:48 PM
Re: Floyd rose problems!
You could try loosening the saddle and sliding it back. That should level that string out and get you back playing ASAP. I had a similar problem and that fixed it right away.
Thund3rDong is offline
post #3 of 8 (permalink) Old 06-16-2010, 09:32 PM
Reviews: 98
Is the whole trem lower on that side--like the stud screw is down a little too much?
AlaskaBat is offline
post #4 of 8 (permalink) Old 07-03-2010, 04:56 PM
Loosening the saddle and sliding it back will throw the string out of intonation. This sounds like an easy fix. Simply raise the bridge a little higher on that one side. It should have an allen screw on either side of the bridge.
Just turn the screw on that side of the guitar counterclockwise at 1/4 turn increments until it feels comfortable.
DevilAnse is offline
post #5 of 8 (permalink) Old 07-03-2010, 07:33 PM
Paw
If it's just the low e-string that's buzzy, you can raise it by putting shims under the saddle. You can also raise the bass side of the trem, although it'll affect the other strings as well.
Paw is offline
post #6 of 8 (permalink) Old 07-04-2010, 01:45 AM
Reviews: 98
Pete and Repeat...
post #7 of 8 (permalink) Old 07-04-2010, 08:23 AM Thread Starter
Thank you everyone for the responses i think i will try the shims. Will let you know how it works.
Vegnjame is offline
post #8 of 8 (permalink) Old 07-04-2010, 02:28 PM
My advice is never turn studs to raise or low bridge on tension. Always remove strings and springs before leveling or you will damage knife edge of tremolo and lose returning point (of tremolo).
peromucho7 is offline
flody rose trem jem broke
Similar Searches
Tuning Problems&OFR(Original Floyd Rose)Question Important! Ibanez/OFR Compatibility atcgtr Tech: Setup, Repairs and Mods 13 12-21-2008 03:18 PM
Floyd Rose Problems (NOT THE USUAL CRAP!) TheMightyTurtleHead Tech: Setup, Repairs and Mods 6 11-24-2003 11:36 AM
Major tuning and Floyd Rose problems Hame Tech: Setup, Repairs and Mods 14 08-11-2003 09:51 AM
Floyd Rose tuning problems with my new RGT42 ericguitar All Other Guitars (including Prestige) 12 04-30-2003 12:04 AM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 12:06 AM
HTML code is On
