Good project guitar for GMC?? - What's the difference? - Jemsite
post #1 of 5 (permalink) Old 02-01-2002, 02:52 AM Thread Starter
The spec on jemsite lists "Great GMC swirl project guitar" in the jem777vbk field. I'm curious about the differences between them(except the finish of the body, of course). Vbk has a back-routed body?? or it's a front-routed one the same with a gmc??
alienasia is offline
post #2 of 5 (permalink) Old 02-01-2002, 09:24 AM
site founder 0% owner
jemsite's Avatar
the VBK is a front route, so you'll probably want a cavity filler or just deal with the exposed front cavity.. glen
jemsite is offline
post #3 of 5 (permalink) Old 02-01-2002, 10:18 AM
since it's a front routed body, a replacement body or the above solution seem the best ways. But it has the same(ish) neck with green vine inlay and stuff so...
7 Dying Trees is offline
post #4 of 5 (permalink) Old 02-01-2002, 12:10 PM
I have looked into the same thing and getting a replacement body seems to be the best deal even if you have a FP. When I started adding up the cost of a donor guitar and replacing hardware, trem pickups, swirling, ect...I found that the cost is not far off from buying an original GMC (assuming you can find one).
big al is offline
post #5 of 5 (permalink) Old 02-02-2002, 02:43 PM Thread Starter
big al on 1:10 am on Feb. 2, 2002
Thank you guys for making things clear, and the problem, like you said, is to find a GMC in good condition.(If one really wants it.)
gmc swirl , swirl project
Ibanez GIO for a good guitar project? snakymen13 All Other Guitars (including Prestige) 27 07-05-2012 11:19 AM
Does this look like a good project guitar? Jeffplaysguitar Tech: Setup, Repairs and Mods 10 02-02-2011 11:29 AM
My god, the difference a good cabinet makes... Drew Gear, Equipment, Recording & Off Topic 20 05-05-2003 12:57 PM
What a difference a set of strings make - ...and also a good ANOVA Gear, Equipment, Recording & Off Topic 9 09-08-2001 12:18 PM
Project Guitar Ideas - Opinions wanted on project jem7vwh Tech: Setup, Repairs and Mods 11 12-19-2000 11:27 PM
HTML code is On
